i need 2 gm part numbers
LS1Tech Premium Sponsor
Cam bolts = Cam Sprocket Bolts...there are just three little bolts that hold the cam gear onto the camshaft. That is GM part#12556127 or ARP#134-1003 (includes all three).
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Yes, if you've got the new style plate with counter-sunk bolt holes, the bolt part number is 11561455
__________________
Looks exactly like the old plate, but the new plate has the holes counter sunk which recesses the bolt when you tighten it down for better clearance....the old ones used a bolt with a regular flat head on it.
__________________
Both the new and old plate were flat...just the bolt holes going through the plate changed. Are yours counter-sunk? Maybe snap a pic and post it for us?
__________________
If they are not counter-sunk holes, I believe the old bolt part number was 11515756.
__________________
http://www.performancetrucks.net/for...=447052&page=3
on that link those are the new bolts u are talkin about right? its in the middle of the page
In that thread, post #28 the cam retainer plate bolts shown are counter-sunk!
__________________
Good deal, then the old bolt #11515756 should work!
__________________
