Help! I think my cars about to blow
Ok i just found a 99 Z28 6 speed with all the options and only 70,000 miles, the dealership only wanted $7,400 for it. So i bought it lastnight, i put $3,200 down on the car and financed the rest. I havent drove the car but maybe 30 miles. I drove it home lastnight and to my parents house this morning. While at my parents house showing them the car, the car started knocking REALLY LOUD. (ive only got into the once, i did a pretty good burnout, thats it!) While showing off the car to my dad, i did the burnout, and RIGHT after that it started the knocking. I noticed the oil pressure gauge had flatlined, it had no oil pressure. So we shut the car off and check the oil, it was still full of oil, but we look really closely at the dipstick and we see LITTLE metal shavings in the oil. Ive talked to a couple mechanics and theyve told me, it sounds like the oil pump has went out and the metal shaving are from the main bearings. They also said most likely the pushrods and piston rods are bent. They told i will need a crank kit and a new oil pump.
Does this sound about right?
(Basically i think im pretty much FUCKED!)
I think im gonna try to get my money back thru the lemon law....hopefully...
No i drove off the lot, with a LS1 that only had 70,000 miles, a clean carfax and i drove it not even 20 miles and i did ONE burnout and it bends a rod. How is that my fault? Hell that could have happend a few weeks later from easy daily driving, and you think this is some how my fault?
Captain Double Post
yeah metal shavings on the dip stick is not good,no oil pressure really not good,is this car all stock,if you went threw a dealership did it come with somekind of warrenty?that car must have had the hell beat out of it for only 70k on the clock,sounds like bearings,that should for sure be under the lemon law, that sucks man, the dealer should eat that one!
To be honest with you it wasnt even that good of a burnout, i may have tagged the rev limiter once or twice, but i deffinetly didnt miss any gears. i only went thru 1st and 2nd and i let off of it
Naa i havent done anything to it yet, i tryed going back to dealership and raising hell with them to get my money back but that didnt get me anywhere. I think im just gonna go talk to a lawyer, im not trying to pay for a car that has bent rods, spun bearing, bad oil pumps, etc...
i never heard of a warranty only covering 500 dollars, **** you can rack that up easily on a small repair! i would definately go talk to a lawyer too... and after i talked to a lawyer about your options i would have him contact the dealership to see if they can work something out instead of going to court which could take forever.maybe even see if the dealership can do it under a warranty repair if you buy an extended warranty from them. i bought a mustang when i was 17 with about 45k on it and blew the rear end out in it 2 days after i got it and the dealership had me buy an extended warranty from them i paid the 100 dollar deductable and car got fixed
Captain Double Post
Well like I said I could see some bent push rods,broke springs, and those are easy to replace,did you try talking to the dealer before popin your top,screaming gets no where,well I hope you get it all worked out,did you have a mechanic look the car over before you bought it? What was oil pressure at from the first time you drove it? Did you test drive it, if you only had it for 20 miles there had to be something on the dip stick before, I guess there is a lesson in all this,
