what causes coolant in engine oil?
I've noticed a lot of condensation and sludge build up under the oil fill cap even
after changing the oil, there is coolant entering the oil but where exactly is this
occurring? I've checked the search but couldn't come up with anything..is it the
head gasket? also the water pump occasionally leaks, any correlation?
^ ditto. And the condensation under the cap is normal, but excessive could be from the HG leak which is condensating on the cap.
I also thought it would be the head gaskets, the coolant wasn't too low but the
consistency was slightly different.. There's condensation and the occasional
build up of sludge under the oil cap
I noticed this on my truck, 6.0l yesterday. Have never seen it before. Kind of a yellowish greasy buildup in the cap. It was really cold last week, -28. Truck runs fine, oil on the dipstick looks fine, normal color, normal level, coolant was a litttle low, but nothing major. It has 118,xxx miles on it right now. I was kinda freeking out a little bit, especially since I have been spending so much $ on my car right now. That's all I need is to have to tear down the truck motor too.
First i would remove my radiator cap and run the car watch for bubbles in the radiator fill neck. If bubbles are present you have either a cracked block, warped head, or a bad head gasket. I had this same issue on my Z which did not turn out to be anything, when i had i found there were no bubbles in the radiator i took an oil sample to a peterbilt dealership and had it tested for contaminents with nothing abnormal showing.
