Which part of Oil Pickup Tube does Oring seat on? (pics)
Old 03-26-2011, 02:28 PM
mattster03's Avatar
Default Which part of Oil Pickup Tube does Oring seat on? (pics)
Okay, it seems like everyone is talking about how difficult it is to get the oring not to "roll" or "pinch" but I can't figure out why?? What do people mean by this? I have a brand new oring and was just wondering which surface it seats on... picture #1 or #2. i'm quite sure is as shown in #1 but I don't want to screw this up!
#1: Up against the ridge
#2: On top of the ridge
Old 03-26-2011, 03:06 PM
I_Need_Land's Avatar
good thing that 2b 141 and can of zip ties is super clear.
Old 03-26-2011, 03:10 PM
Fratsit's Avatar
Old 03-26-2011, 04:58 PM
mattster03's Avatar
funny guys. the picture is good enough to show what i'm talking about. this should be an easy answer for someone...
Old 03-26-2011, 05:19 PM
Paul57's Avatar
Everyone's a comedian.
I would like to know also. My opinion is #2 but that is strictly a guess.
Can you tell by looking into the block opening if there is a place for the o-ring to sit like you have it in pic 1??
Old 03-26-2011, 06:02 PM
Pocket's Avatar
Press the tube and O-ring into the pump by hand to ensure a flat seal, then put the 10mm bolt in
Old 03-26-2011, 08:07 PM
mattster03's Avatar
Bump up... can anyone confirm this?? I could swear it should be done like shown in #1
Old 03-26-2011, 08:19 PM
intermediate skool's Avatar
AGREE 100% to that statement!
then torque 10mm bolt to 106 in lbs.
Old 03-26-2011, 09:13 PM
joecar's Avatar
It should be in the groove as in pic #1.
Old 03-26-2011, 09:30 PM
mattster03's Avatar
I knew this was going to happen... which one is it guys?? Quite honestly I still think it's got to be like #1 as ^^^ suggested
Old 03-26-2011, 09:35 PM
stangtrader's Avatar
I agree on on #1. My pickup had a black mark from where mine was sitting before disassembly.#2 is sketchy to me but both make sense but #1 makes more due to the fact the bubble on the pickup presses the prong against the machined grove in the pump. But I'd still want a GM techs opinion
Old 03-27-2011, 12:56 AM
kagato's Avatar
I own a GM service manual for my 98 and am looking right now! It doesn't specify if its against the ridge or all the way on, like trader said I bet its against the bump and not all the way on. the bump is probably there for this reason.
The crucial thing the manual states is this
IMPORTANT: Push the oil pump screen tube completely into the oil pump prior to tightening the bolt. Do not allow the bolt to pull the tube into the pump.
Old 06-22-2012, 08:43 AM
98CamZ28's Avatar
Bump!! I can't remember which is the correct way, any help?
Old 06-22-2012, 10:52 AM
wildcamaro's Avatar
I always do number 1 and after seating in the oil pump install bolt and torque to spec
Old 06-23-2012, 09:38 PM
gMAG's Avatar
#1. The metal ring of the pickup tube then exerts equal pressure on the o-ring.
If you put the o-ring on as #2, when the pickup is inserted, the (blue) ring may not seal well.
If you use the green o-ring, which is fatter, you might be able to get away with #2.
Old 06-23-2012, 11:35 PM
01_SuperSlow's Avatar
#1 for sure. Nice pics!
Old 06-23-2012, 11:46 PM
crazyelf's Avatar
#1 is how I did it
Old 06-26-2012, 03:14 PM
BOXCHEV's Avatar
Bump! TTT!- Was just getting ready to put the oil pan on. Glad I did a search first to make sure on this pickup tube.
I couldn't even get the O-ring to sit down in position #2 like above it just kept popping back up before I could take a pic.
Hope this is clearer for everyone to see. #1 Seems to make more sense. Maybe its pushes up to #2 when fully pushed in and the bolt torqued down.
Old 06-26-2012, 04:14 PM
BOXCHEV's Avatar
Seemed to have misplaced the bolt for the pickup tube.
Anyone know what size bolt it is?
Old 06-28-2012, 10:41 PM
Randy WS6's Avatar
#1 is were it goes, the #2 is to seat the o-ring in the oil pump, it presses the o-ring against the oil pump housing course it to swell to make a tight seal .
Quick Reply: Which part of Oil Pickup Tube does Oring seat on? (pics)
