Yet another good reason to degree your cam
Old 04-03-2011, 09:26 PM
LilJayV10's Avatar
Default Yet another good reason to degree your cam
When I was younger and didn't know anything I never degreed a cam when I installed it. Just dot to dot. I like to think I'm smarter now than I was then. When I did my H/C/I/E swap on my 00' Hawk I degreed the EPS cam I got. It was suppose to be on a 110 ICL and it was about 111.5 I think. After degreeing it ended up at 109.5. Close enough for me.
I built a 355 LT1 for my friend. We degreed the cam he got from Lloyd Elliot, it was suppose to be at 110 and it was at 113.5 I checked it three different times and got the same numbers each time. We picked up the comp cams bushing kit and used the 4 degree bushing and ended up at 109.5 Again close enough for me.
From what I understand from the comp cam video that the ICL changes what RPM the powers at not necessarily total power. If that's is wrong someone with more knowledge(not that it would take much)please throw some input in here.
Old 04-03-2011, 10:20 PM
Paul57's Avatar
That is my understanding also but I am not an expert either...moves the power curve(rpm) but not necessarily total power.
Old 04-03-2011, 10:25 PM
LilJayV10's Avatar
Hopefully Damian or someone will chime in.
Old 04-03-2011, 10:35 PM
LS1Z28-00's Avatar
im installing a 228r in my car and i have no plans to degree it, im just doing dot to dot like most people do, would like to hear input though.
Old 04-03-2011, 10:43 PM
Paul57's Avatar
I don't understand how the angles can be so far off. You would think with todays technology and precision tooling that you wouldn't see more the .5 degree off.
Old 04-04-2011, 07:23 AM
gtotoocool1's Avatar
part or most of that could be due to tolerance stacking.example:
cam is off a little.
timing gears/chain are off a little
crankgear is off a little.
add all that up and it can throw you off a couple of degrees easy.
Old 04-04-2011, 07:34 AM
PREDATOR-Z's Avatar
By changing the ICL, you are changing the valve events. This affects power and location of peaks in the band.
Old 04-04-2011, 10:07 AM
LilJayV10's Avatar
Thanks for the post PredatorZ!
Old 04-05-2011, 12:19 AM
lexva_58's Avatar
sorry for the noob question..
but then how do you degree a cam?????
does it really affect that much not to degree it???
never thought about it
Old 04-05-2011, 04:50 AM
crainholio's Avatar
http://lmgtfy.com/?q=how+to+degree+a+cam
There's something you should try. The brain is not a finite resource, you can use it all you want and never run out of it.
Old 04-05-2011, 05:56 AM
PREDATOR-Z's Avatar
Well that could be the difference between a cam that has the potential of yielding a 50rwhp increase and one that just gives you 35. All this leaves you wondering why YOUR setup doesn't put out the same numbers as Mr.X
Attention to details can yield the extra power so dearly thought and paid for.
