How much PTV clearance is required
Minimum recommended values are 0.080" intake and 0.100" exhaust. One note on the values. For the intake valve, it is usually chasing the piston down the cylinder so you may be able to run a little tighter. On the exhaust, the piston is chasing the valve as it closes so you may want to have the minimum here. Good springs and valve train control are mandatory. Also, don't forget the entire valve train is a system of springs with one of the most flexible being the pushrod.
its not for my car... But the car in question has heads milled to 59cc, running a GM MLS gasket, a 242/244 vindicator cam and already has 90 thous flycuts on both intake and exhaust. It clears with a little bit of breathing room but just checking to be sure. The exhaust valve has a mile of clearance.
With this car, i cut through the clay with a razor blade and measured with feeler gauges, looks to be aprox .090 of clearance on the intake, a TON on the exhaust. I think we are good to go, going off the ideal readings people have posted here.
