stock ls1 cam to ls6
i am new to this website and the ls1, but i am going to put one in my 68 firebird and of coarse i dont want to put a stock ls1 in there, first of all can i and second what kind of gain will i see from putting a ls6 cam into a stock ls1? thanks for the help
and oh yea, what about a ls6 intake on top of that? thanks
daniel
daniel
Originally Posted by 68bird
how much do you want for the cam? and your talking rwhp right?
well i am looking to make about 375 rwhp on stock heads! that is all i want for now, then later i will go into the heads to find some more and put a more aggressive cam in there. so really what would be a good combo for that? thanks for yall's respones
daniel
daniel
daniel
daniel
well the car will be a street/strip car, but mainly my driver. so the lower the cam kicks in the better. i still want the motor to be a perfromer in the upper rpm range, but have good low end torque. i will most likely have the 4L60E tranny, and i am not certain what is in the rear of my 68bird right now, but i will probably have anything from 3.42 to 3.73 gears.
A ls6 cam would be a ok choice, but if your going for 375 rwhp on stock heads, i would posibally go for something bigger, especially being the motor isn't in the car yeat(i assume). Send the computer off and get it tuned, and I think you would like that much more.
I mean, whats better than a late model performance engine, that lopes and sounds like a hot rod, and runs with the big boys?
what kind of cam would you recommend then? would changing out the springs be a wise descions with that cam? would ls6 springs be a good choice? thank you
daniel
daniel
i just went to the thunder racing website after someone telling me to check out the 224/224 112 cam, and i think that is just what i need. it will work with my stock heads, but i need to change out the springs, and that is all that i am looking for right now. so with that cam and springs, ls6 intake, set of lt's with true duals (it's on a 68 firebird, much easier to get em lol) what kind of power do you think i will make? and should i add anything else on there at this stage? thanks for repling
daniel
daniel
