Fast intake question
LS1TECH & Trucks Sponsor
I would do the 102mm if you are looking for a brand new intake. Whenever FAST came out with the 102's they discontinued the 92s so they are a bit harder to find. The 102s will make a little more power then the 90's and 92's once you have heads/cam on the motor.
I gained some crazy torque with my 102 over the LS6 intake. The intake will only flow as much as the heads will. The 102 is just a better designed intake over the 92 and 90 design, and the 5cfm flow difference (unported) on 243 heads @ 4" bore show that there IS a definite difference between the 102 and previous designs. It's just about which one you prefer at this point. If you want the biggest and newest; 102. If you're indifferent; 92/90.
