Tune and Injector question
I will be installing a TSP 228R (228 /228 588/588) cam and a set of PRC LS6 Stage 1 heads on my 1999 Corvette. The car already has long tube headers, LS6 manifold and a Vararam. Its a 6 speed manual.
Will I need to replace the injectors? If so, whats the recommendation?
Will I be able to drive it without a tune? (Just to get to the place to tune it, its about 50 miles)
Thanks!
Thanks!
He is adding heads-that is an internal mod along with the cam.
Yes you will need injectors. Your tuner should give you ideas. I like the white plastic Boschs from the SC GMs-identical to the ones on your car now sans the color and can support 500 easy. Hard to say if it will be driveable with them on-why not get a mail in tune from Frost so car is driveable till a real tune? The other good idea is driving it with theold injectors(car may stall out though)on like mentioned.
