Other things to do when doing a cam install?
Old 09-22-2011, 08:03 PM
LeavinHard's Avatar
Default Other things to do when doing a cam install?
So Ive been reading a pretty good bit about doing a cam in the formula. From what ive read when doing a decent size cam you need to do valve springs, retainers, and push rods. Ive also read that you should do a LS2 timing chain and a ported LS6 oil pump when doing the cam. Would it not hurt to do a water pump as well? If so what kind of water pump? Stocker or some sort of aftermarket?
Old 09-22-2011, 08:06 PM
kwiksilverz28's Avatar
LS2 water pump. Also, get the Melling 296 oil pump. Skip the ported LS6. I also had my rockers rebuilt by Harland Sharp.
Old 09-22-2011, 08:13 PM
LeavinHard's Avatar
Ok cool thanks for the info. Just making sure I have everything I need. As far as the cam goes im kinda torn between the Tr224/224 or the Trex. Ls1's are new too me as I just got the car recently. Im looking to put down 400whp or more if possible with just a cam and bolt ons. Its a 6 speed car.
Old 09-22-2011, 09:13 PM
Don't be shy with cam. We did a friends car, and with ported and milled crappy 98 heads and a Futral cam along the lines of 232/232 112+4 .600/.600 and put down 410hp with something like 140k miles on the short block.
http://www.fquick.com/garages/Chevro...Z28/1998/8911/
Drove perfectly fine as a dd.
Old 09-22-2011, 09:35 PM
z28241's Avatar
U will probably want to swap ur stock lifters for LS7's and add LS2 lifter trays as well..
Old 09-22-2011, 09:52 PM
j_tizzle_84's Avatar
definitly good insurance to do arp rod bolts and double roller timing chain with increase in red line. and no body mentioned injectors.
Old 09-22-2011, 10:12 PM
massls1guy's Avatar
I didn't do the water pump. But it's a great time to put in a new thermostat while the pump is off.
Old 09-22-2011, 10:38 PM
LeavinHard's Avatar
so I should also do lifters and the trays as well? Is that a must mod?
Old 09-22-2011, 10:39 PM
I will disagree. LS2 chain is fine. Also, messing with rod caps can invite trouble as I have read...... Lifters should be fine if motor was well maintained....
My requirements to do a cam job were cam, chain, oil pump, gasket set, and beer. Lol
Old 09-22-2011, 10:40 PM
Most do not with just cam job.....
Old 09-22-2011, 10:50 PM
LeavinHard's Avatar
ok cool thanks guys for all the input
Old 09-22-2011, 11:16 PM
01ssreda4's Avatar
I like to do upgraded injectors, LS2 timing set, and a Melling 10295 high pressure pump.
Old 09-23-2011, 12:32 AM
2004yjgto's Avatar
I agree^^^ I would definately want bigger injectors
Old 09-23-2011, 07:20 PM
Agreed, but skip Melling 295 and get the 296. You can run the lower pressure spring.....I run the high pressure and haven't had any problems....
Old 09-23-2011, 09:31 PM
ggino85's Avatar
what injectors would you guys recommend upgrading too?
Old 09-23-2011, 10:04 PM
Depends on goals. I am pushing upper 400's on 42# racetronixs. I almost wish I went 60's, but my next upgrades will hopefully need more than that....
Old 09-24-2011, 02:00 AM
Black 99 Bird's Avatar
He will be fine with the stock injectors at that power level. Don't worry about pulling the heads to change the lifters either.
