418 LQ9 What cam to run?
Old 09-23-2011, 01:27 PM
syclone74's Avatar
Default 418 LQ9 What cam to run?
Hey guys looking for some suggestions. I have a newly built LQ9 stroker 418CI and was wondering about a cam choice for this. I have the TPIS 90mm intake and throttle body, PRC stage 2.5 5.3 heads with 2.10/1.60 valves, long tube headers and SLP exhaust, underdrive crank pulley. Any suggestions appreciated I have a Torquer V3 with 200 miles on it out of my 346 but dont know if this would be a good cam for this motor? If not would be willing to sell it.
Old 09-23-2011, 03:11 PM
syclone74's Avatar
Any thoughts?
Old 09-23-2011, 03:19 PM
NC98Z's Avatar
I would ask TSP since your running their heads.
Old 09-23-2011, 05:42 PM
PREDATOR-Z's Avatar
Ditch the TSP heads, those are seriously mismatched to those cubes.
Old 09-23-2011, 07:56 PM
syclone74's Avatar
What would be a good set of heads for this?
Old 09-23-2011, 08:10 PM
ss454327's Avatar
TFS 235s...
Old 09-25-2011, 03:17 PM
A.R. Shale Targa's Avatar
Originally Posted by ss454327
TFS 235s...
THIS ^^^^^^^ w/TEA guide upgrade (stock rocker compatible)
Your current cam will be all done by 5800 w/418"...perhaps a custom in the
range of 238-246 @ .050 will get you to 6400-6500 range
Old 09-25-2011, 04:14 PM
LSOHOLIC's Avatar
This may be a little off topic but.......I never understood the "help with cam selection" posts. Agreed there maybe a COUPLE cam guru's on this board but it is truely hit or mis. IMHO...just call the pros..the ones that will make a spread sheet on your combo and give you options with moving the valve events around to compliment your specific combo.
Examples..
Erik @ HKE
Steve @ LSM
Geoff @ EPS
Mark @ Bullet
you get the idea and the list goes on....pro, as in they make a living dealing with these variables.
Here is a thread on the bullet that will be a good read for your situation...
http://www.yellowbullet.com/forum/sh...d.php?t=410450
Thanks...and good luck with your build.
Old 09-25-2011, 04:38 PM
silverstreak98maro's Avatar
U will not be happy with the v3 off the shelf in that motor and also id say ditch them heads as well on that motor a buddy of mine has 418 too n has custom cam on its way and is using stage 2.5 ls3 heads call charlie at futral motorsports bro thy will spec out what u need
Old 09-26-2011, 03:53 PM
syclone74's Avatar
Thanks guys for all the info!!!!
Old 09-26-2011, 06:46 PM
garygnu's Avatar
to bad you already have a intake ,some stock l92 heads wood work ok .
Quick Reply: 418 LQ9 What cam to run?
