6 liter iron block
First: quantify "big power." Second: Forced Induction, nitrous, or all motor? If you're thinking upwards of 700hp, I would stick to .030 and under. Also, having the block sonic tested for casting flaws, voids, or weak spots isn't a bad idea either... It could save you a lot of money in the long run.
4.030 to 4.040 for big spray usage or other Forced Induction or best reliablity and leaving room for prior rebuilds, etc. 4.060 is the max for N/A and 100 shot to play it safe BUT YOU MUST GET IT SONICE TESTED as many of the new blocks are to thin where it counts for the .060!
