switching from Lunati 395 to a 434
Old 03-09-2004, 02:38 PM
kumar75150's Avatar
Default switching from Lunati 395 to a 434
Hey guys, I am thinking about adding a resleeved block and upgrading from my Lunati 396 to a 434cid motor.
Besides the resleeved block, I know I will need pistons for the bigger bore and do more headwork (bigger valves).
Will I need anything else?
Old 03-09-2004, 02:44 PM
30th TA 0219's Avatar
buckets of money
fresh undies for the even faster ride!
Old 03-09-2004, 03:18 PM
kumar75150's Avatar
well besides the machine work, an ARE sleeved block is $2000 and comes with a warranty. Add to that a few hundred bucks for pistons.
Old 03-09-2004, 03:19 PM
Nick Agostino's Avatar
Rings, bearings, balancing, camshaft?? bigger, injectors?, programing, oilpump, recc. opening up the heads for the bigger bore and possibly port volume increase depending on where you are at with the current heads.
Old 03-09-2004, 03:48 PM
Trojan T/A's Avatar
Sounds like it would be better to first sell the 396 and then go for the 434. What is your current compression ratio with the 396?
Old 03-09-2004, 04:23 PM
kumar75150's Avatar
Compression ratio is 11:1 right now I think.
I already have a cam big enough for the 434. 244 250 duration. I am about to open up the cylinder heads also with bigger valves.
Injectors and oil pump should be good because I am already making around 500rwhp w/o any issues. I want to make close to 550.
So sounds like pistons, rigns, bearings, balancing and machine work.
I will talk to my engine builder and see what he says.
Old 03-09-2004, 04:54 PM
maddboost's Avatar
Well with a larger bore your going to need heads that match that bore.
Old 03-09-2004, 05:01 PM
kumar75150's Avatar
Ya I am already going to have bigger vavles put in my heads.
These days, many tuners are putting in 2.055 or 2.08 intake valves even on stock bore cars.
Old 03-09-2004, 05:45 PM
Nasty N8's Avatar
I can get you a good price on the sleeved block as I am doing a couple right now the more the better. Let me know if I can help you out.
Nate
Old 03-09-2004, 07:13 PM
H82BBad's Avatar
can you beat the 2000.oo posted for the are block?
Old 03-09-2004, 07:17 PM
1fstTA's Avatar
I would also like to know what you charge for the block work im in the process of getting ready for the 422 build up right now.
Mike
Old 03-09-2004, 08:12 PM
*Edited By Big Mike** Nick, Please understand that as a Non-Sponsor, you cannot post prices here. Thank you...
We hope to be a sponsor soon again and would do a gp on them no problem. hopefully we can resolve things soon and begin to advertise as a vendor here
Old 03-09-2004, 09:27 PM
Cliff's Avatar
NastyPerformance: I would like to know the same thing as I am in the process of building a 427. Thanks.
Old 03-09-2004, 09:49 PM
kumar75150's Avatar
more importantly, does nasty performance offer a warranty if you purchase the block only?
Old 03-09-2004, 09:59 PM
No problem Mike, someone quoted a price on our resleeved block and it was wrong, I was just correcting the inaccurate information Am I aloud to correct wrong information?, send me a note what I can and can't do. I am sure other vedors would rather see a non sponsors pricing be corrected to a higher amount Better for them.
I didn't post the pricing just trying to correct, sorry as I must have offended someone; non intended
Old 03-09-2004, 10:09 PM
Cliff's Avatar
Nick..........what does your Warranty consist of on your resleved blocks? If I did business with you again.................are you going to hold up to the warranty?
Old 03-09-2004, 10:23 PM
Not sure I can post this information (no pricing though )
do they come with a warranty if I purchase the block only?
ttt
Our resleeved blocks do come with a warranty even if they are purchased as a block only sale. If we assemble install and tune the warranty is 2 year/24,000, if the block is sold outright only there is a limmited 1 year 12,000 from dropped sleeves or water leakage. This warranty is void if there are any signs overheating or extreme detonation. Blown headgaskets and water entering the cylinder causing a hydraulic situation would also void warranty. There have been a few issues with these engines way back and have warrantied all to the customers satisfaction.
With the process we use it is virtually impossible to drop a sleeve or have a water leak.
We will be having a special in the next week or so as soon as the next batch of sleeves arrive at the shop, we also have blocks in stock and can sell them outright with no core needed
We had a few N2o misshaps over the years and replacing sleeves in a hole hear and there is not a problem either, just not under warranty . We do help out our customers with special pricing in these kind of situations
Part of our warranty would deffinately include working with the engine assembler as well as the installer, we want to give as much support to the builder and installer as possible as we all know how miscommunication can cause problems
I don't think anyone can afford to warrante anything due to miscommunication We are commited to supporting all our products
Old 03-09-2004, 10:30 PM
Cliff's Avatar
Please e-mail me your "special pricing". I'm interested.
Old 03-10-2004, 07:52 AM
DG Gordon's Avatar
Do you not like the 395 motor? I am having one built for me and was wandering if it will be worth it?
Old 03-10-2004, 08:56 AM
jyeager's Avatar
Have you already upgraded your intake/throttle body or are you making due with stockers now?
