6.0 heads
need help
Ok here is what I got. I have a 6.0 block out of a 99 full size truck and I also have a set of 6.0 heads off a 2001 truck. What do u guys think my compression ratio would be? And what kind of cam do u guys think i sould go with and yes Im going to spray it?
The LQ9 is the 6.0 HO with flat top pistons. The LQ4 is a low compression 6.0 with dished pistons. They share the same heads, both having 71.06cc chambers..
Check info here:
http://www.gm.com/automotive/gmpower.../apps/vehicle/
