trick flow stage 3 cam?
I just bought a trick flow stage 3 cam for my 98a4. This is goin to be my first ls1 camaro build and i wanted to know if any one has used this cam yet without the trick flow heads. I will be installing the cam along with ls6 243s. I have already istalled 1 3/4" LTs and o/f y-pipe. Any results or advise on this type of setup?
Captain Double Post
the trick flow cams are not that bad, a few guys i know use them and honest they have made some great numbers, most people will hate on trickflow just because not many use there cams so people think they are junk for that reason,i think you will love that cam with a good set of heads
I have the same exact cam in my setup: made 390/390 cam + bolt ons only and 440/408 with heads, ported FAST 92, full bolts ons, etc.
As stated above, it's relatively mild and makes good power throughout the band. Great street manners. In my opinion, its the perfect "middle-of-the-road" cam.....good compromise between performance and driveability.
You should be pleased with your selection. I've always liked my setup. That being said, if I had it all over to do again, I'd probably get Pat G to custom spec a cam that matches up with all of my current mods.
I think i will be happy with the performance of this cam based on what i have heard so far and i do plan on getting 3.73 gears. Thanks for the info so far and any other suggestions related to performance that would help out an ls1 newbie would be great.
I love this cam. Made 432/399 11.71@117
lq4 Shorblock
stock 243's
ls6 intake
stock 28 injectors
SW headers 2.5 collectors into a 3in I pipe. Cutout open.
4L60 with 9.5 2600 Edge converter.
Car is an 89 Formula
lq4 Shorblock
stock 243's
ls6 intake
stock 28 injectors
