misfire after head swap
Old 01-10-2012, 01:20 PM
buzb026's Avatar
Default misfire after head swap
my car has stock tune and now has longtubes ORY and catback. put some ported 243's on and i am getting a misfire in cylinder 5. could all this air flowing through on stock tune cause a misfire?
Old 01-10-2012, 01:29 PM
krissoto's Avatar
only if it might have fouled the plug. Change the plug and chk your connections on your coil packs and wires .
Old 01-10-2012, 02:22 PM
Burken01's Avatar
this ^^^, my car was misfiring and my check engine light was on.
I plugged my diagnostic obd2 scanner in, and i had cylinder 8 out..
just replaced the sparg plug and it was fixed..
the plug might of got damaged during the swap or if you reused them it might of fouled out..
Old 01-10-2012, 02:24 PM
Burken01's Avatar
and check your spark plug wires, make sure you hear them click when you press them on... grip the boot of the plug wires when applying pressure, if you dont then sometimes it wont click in, even though it still looks connected.
Old 01-10-2012, 06:10 PM
squirlNUTZ's Avatar
I had a miss fire code after my engine swap. Turned out to be two things: I has damaged the map sensor pig tail, and the intake rocker arm on number 4 had come off and was laying there next to the pedestal
Old 01-10-2012, 06:13 PM
djfury05's Avatar
check the grounds on the back of the heads also
Old 01-10-2012, 06:16 PM
TransAmcoupe98's Avatar
Check your coils
Old 01-10-2012, 11:43 PM
buzb026's Avatar
turns out one of the injector connectors had come loose. thanks for all the insight.
Old 01-11-2012, 12:06 AM
mannyman84's Avatar
So sime yet hard to find if you don't do the basic inspection. Good job OP
