241 vs 243 vs 799 heads good price?
Old 02-09-2012, 10:06 AM
needtransam's Avatar
Default 241 vs 243 vs 799 heads good price?
Ok I have an 01 camaro that came with the 241 heads, im wondering should I port this stock heads or get some 243 heads? if so what is a good price to pay for 243 heads or even 799 heads?
thanks
Old 02-09-2012, 10:11 AM
redtan's Avatar
Depending on who ports your stock heads, they could be either equal to or better than stock 243s. With 243s though, you have more room to grow afterwards vs. a radically ported 241.
You can easily find 243 heads for 4-500 bux.
Old 02-09-2012, 10:13 AM
autogeek23's Avatar
and some go for under $400. but they go fast
Old 02-09-2012, 10:15 AM
thunderstruck507's Avatar
Ported 241 can perform very well, but something always comes up when I work on my car so I like to have as many ducks in a row as possible. That's a big reason I bought some 799s to have ported then just install them later.
If you look around and find a good deal you can get 243/799 heads for ~$300 and get them ported. You can sell your stock heads for $100-150 to get some of that back.
Old 02-09-2012, 10:23 AM
yeah there is someone selling 243 heads of a zo6 corvette with 40 k miles for 500 obo
was wondering if it was a good deal to maybe offer 400?
Old 02-09-2012, 10:24 AM
The z06 heads have lighter valves which are worth more $$$.
Old 02-09-2012, 10:28 AM
I believe the zo6 heads have this specs?
yellow springs and hollow intake and sodium filled exhaust valves
Old 02-09-2012, 11:26 AM
baxsom's Avatar
you have to know exactly what year the heads came off of. 01 Z06 engines had the 243 heads but did not have the hollow/sodium filled valves. that was only the 02-04 z06s. 243 and 799 heads are the same design and flow the same. you can pick up used 799/243 heads all day every day from ebay for 350-400 dollars. a rebuild and flatness check will cost you parts plus 200 dollars or you can send them to advanced induction to get some work done for 500+ depending on what you want to do.
Quick Reply: 241 vs 243 vs 799 heads good price?
