pp stg 2 5.7 heads-224r cam dyno results
Old 03-20-2004, 05:12 PM
1fastmfc5's Avatar
Default pp stg 2 5.7 heads-224r cam dyno results
dyno 2/5/04: 325 rwhp/340 rwtq
mods:ss3200,3:42,shorties,off road x-pipe,no mufflers-straight pipes,cold air induction,ported tb,ls6 intake,ls1edit tune,-best 1/4=12.50@111-1.80 60 ft.
dyno 3/15/04: 398 rwhp/385 rwtq
new mods: patriot performance stg 2 5.7 heads milled .030,tsp 224r cam,Lt headers,ls1 edit dyno tune.new 1/4 times next week.
my car is a 98 vette a4 w/70k.
ok my feeling on this new setup is good. driving the car home from the shop the car pulled very hard on the hwy from 70-140mph. it just feels like it has more power from 3k-6200 rpm. for the price of this pkg its a real bang for the buck. $1550 for h/c(TSP),gaskets,bolts,pushrods, added new timing chain & oil pump for $95, used Lt headers $450.
the installation went great, Dave at Combination Motorsports here in vegas really did a great job and had it done within 2 days and Seth got me 40 hp off the dyno tune.
no problems with these patriot heads. idle could be brought done a bit(sounds mean), and let me tell you this thing is verrrry loud. times will be posted next week.
Old 03-20-2004, 05:26 PM
TVWilkes's Avatar
That will one fast,very streetable setup.
Old 03-20-2004, 05:54 PM
BoneSS's Avatar
Great numbers! Makes me want to order the Perimeter Bolts' even more, if summer would just get here a little sooner...
Old 03-20-2004, 06:13 PM
mikemodano9c's Avatar
stock converter?
Old 03-20-2004, 06:16 PM
Mike98WS6's Avatar
Great #'s. Good luck with the set up! U can't go wrong with those heads.
Old 03-20-2004, 06:28 PM
BoneSS's Avatar
It says ss3200 in the post for the converter.
Old 03-20-2004, 07:10 PM
JZ'sTA's Avatar
Sounds very promiseing. Good luck.
Hopefully you have at least a ET street for the track with the new setup.
If you do except 1.6 60's and 11.8's and better.
Let us know how it goes.
Old 03-20-2004, 07:35 PM
mike m's Avatar
so this was with a totally open exhaust? that car has got to be loud. Too bad you didnt do a dyno of before and after from the shorties to long tubes. What do you think about 10 hp difference from just that. Good Luck with your setup.
Old 03-20-2004, 07:48 PM
Navy David SS's Avatar
Congrats.
I'm sure that track times will equally immpressive.
David
Old 03-20-2004, 08:00 PM
BoneSS's Avatar
Kind of off topic, but when you buy the TSP/PP package, do you have the option of sending in your heads for a credit since there is no core requirement? I thought I read you got 200 off, but I could be very very wrong.
Old 03-20-2004, 08:05 PM
With the PP heads no core is required and never heard of someone buying back the cores. Why do we hang onto a set of heads we will more than likely never use again? I don't a clue - mine will be just taking up space.
David
Old 03-20-2004, 09:02 PM
LS1TECH Sponsor
foff667's Avatar
good #'s with a pretty small cam...congrats
Old 03-20-2004, 09:10 PM
Dave00C5's Avatar
Nice Numbers.
Old 03-21-2004, 03:23 AM
gomer's Avatar
Congrats on your new found "cheap" power
Was that dyno locked or unlocked?
Old 03-21-2004, 06:42 AM
1fastmfc5's Avatar
I'm hoping to see a high 11 sec timeslip next friday.It's getting hot here so i don't know if that will be possible. i'll be running niito drags($200 for new pair-used) this car is sooo loud thinking o changing sig to 1loudmfc5. will post 1/4 times next week
Old 03-21-2004, 07:52 AM
AKRA's Avatar
Congratulations on your new Mods. Stage 2 Heads and a Cam are also my next venture.
You will probably need to consider a roll cage next. If you go faster than 11.5 or 11.99 in the quarter, (depending on which rulebook they follow) they will make you get a cage. At our local track it’s 11.5 seconds. I personally don’t want a cage.
I figure when I get the S2 Heads and a TR224 cam it will still have a nice street matter but run around 11.6 sec quarters. If it goes faster I’ll use LS1 edit to dial my shift points to where I don’t have to get the cage.
I’m looking forward to see your track times.
Good luck,
Al
Old 03-21-2004, 09:59 AM
pdd
pdd's Avatar
same setup i got. works great
Old 03-21-2004, 10:50 AM
LS1Tech Premium Sponsor
Jason 98 TA's Avatar
Congrats on the new setup! That 224R or the new 225 camshaft both make great power for daily driver camshafts! The perimeter heads have worked really well for people, combine that with the $999 pricing & I bet we'll have some of the usual Patriot bashers coming into this thread pretty soon...
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old 03-21-2004, 01:14 PM
LS1SS4ever's Avatar
nice number wating for time !!!!
Old 03-21-2004, 03:56 PM
JoeyGC5's Avatar
No no, my friend. He's got the 5.7 liter heads, where you've got the 6.0 liter heads
Good numbers, that think should go like a **** at the track
Quick Reply: pp stg 2 5.7 heads-224r cam dyno results
