Camshaft won't move....
Old 03-02-2012, 08:24 PM
motenkjr's Avatar
Default Camshaft won't move....
By hand that is. I'm in the process of changing cams and finally got the crank pulley off. If I put a screwdriver between two bolts then I can move it although kinda notchy (first time doing this so it may be normal). And the crank would barely move by hand. Is my engine messed up and I cannot get the cam to budge by hand so how the heck do I get out of the car?
Old 03-02-2012, 08:30 PM
poltergeist 02's Avatar
take the valve covers, rocker arms off. then pull out the push rods. spin the cam to retain the lifters in thier cups and install 5/16 dowl rods in the two hols behind the cam sprocket to make sure the lifters stay in the cups.
Old 03-02-2012, 08:33 PM
motenkjr's Avatar
I meant to say how do I get it out of the engine lol. Sry.
Old 03-02-2012, 08:34 PM
motenkjr's Avatar
But a problem I'm having is that I can't spin the cam with my hand at all....at least not without the use of a screwdriver.
Old 03-02-2012, 08:35 PM
did you take all of those parts off?
Old 03-02-2012, 08:36 PM
your cam will NOT spin freely if there is valve spring load on the rockers.
Old 03-02-2012, 08:43 PM
sepsis's Avatar
You have to do like poltergeist said bro, loosen the rockers and remove the push rods.
To get the cam out, you have to pull the radiator out to make enough room to get it all the way out.
Old 03-02-2012, 09:17 PM
gMAG's Avatar
Remove the rockers. Remove the pushrods.
After this, rotate the cam a couple of times to drive the lifters high into their bores.
Once the lifters are moved, you should be able to gently & carefully turn the cam as you pull the cam out by the three bolts. I was able to get a thumb and index finger on the cam from above (toward the rear of the block) to assist in the removal.
After the cam is out, there is the possibilty that a lifter can fall into the oil pan. I've never had this misfortune.
Old 03-02-2012, 09:51 PM
01SOMZ28's Avatar
Just go to Home Depot and get some wooden 5/16 dowels to slide into the engine so you don't drop a lifter into the oil pan. That's what i did, worked perfect.
Old 03-02-2012, 10:15 PM
^^^ same here.
Old 03-02-2012, 11:12 PM
motenkjr's Avatar
Ok. Thanks. I wasn't understanding fully at first. I'll get on it Sunday morning unless I can sat night. Will I have to get new gaskets btw?
Old 03-03-2012, 02:31 AM
baxsom's Avatar
ls1howto.com
dude seriously, put down the wrench and start reading. maybe even buy a service manual. You are going to mess something up bad. You cant just yank a cam out without doing a lot of preliminary work first. good on you for doing it yourself but please read for about two straight days first.
Old 03-03-2012, 07:15 AM
redbird555's Avatar
Originally Posted by baxsom
ls1howto.com
This^^ man I dont want to sound rude but making sure you disassemble the valvetrain before removing the cam is like number 2 on the list. Go here and read it will walk your through the entire process, be careful its not hard but you must be very detail oriented. If you drop a lifter or misalign the timing chain it will cost a lot of time and money.http://ls1howto.com/index.php?article=23
Old 03-03-2012, 07:33 AM
RADEoN's Avatar
Motenkjr makes another thread:
Dropped a lifter into my oil pan, what do I do?
Then, broken valve springs... Why?
Old 03-03-2012, 09:51 AM
motenkjr's Avatar
I did read that but I'm pretty sure now that I didn't pay as much attention as I should have. I'll go over it again. Thanks to all that helped and everyone else...well....whatever...
Old 03-03-2012, 10:14 AM
Predator's Avatar
That "ls1howto" document is seriously an amazing piece of work. I followed it exactly as written, and yes, as redbird says, the devil is in the details. As an example, I spent nearly a whole day cleaning the bolt holes and removing the old gasket. If you follow that document exactly as written you can't go wrong. If you start winging it you're asking for trouble.
Old 03-03-2012, 11:20 AM
crainholio's Avatar
Wow, imminent failure plus an attitude. This poster has potential for real entertainment!
Old 03-03-2012, 11:51 AM
gMAG's Avatar
Aye, Aye, Capt. Picard!
Number One
Old 03-03-2012, 04:56 PM
motenkjr's Avatar
There is no attitude. Just stating that the smartass comment wasn't necessary nor helpful.
Old 03-03-2012, 05:03 PM
also if and when you get the cam in and start to assemble, be sure to torque everything to spec. you will need a torque wrench.
Quick Reply: Camshaft won't move....
