biggest cam stock heads
Old 03-19-2012, 01:44 PM
ktm8125's Avatar
Default biggest cam stock heads
i was wondering what the biggest cam i could do and do the stock heads pushrods and valve springs
Old 03-19-2012, 01:51 PM
john shea's Avatar
I'm not a mechanic but I believe new valve springs are mandatory.
I'm sure someone will chime in with a cam and spring combo for you.
Old 03-19-2012, 01:52 PM
Camaroking1996's Avatar
Any cam bigger than stock will require you to use new springs.
Old 03-19-2012, 02:06 PM
VandykeT/A's Avatar
You need springs and pushrods with any cam.
Old 03-19-2012, 02:20 PM
Zmg00camaross's Avatar
^^^ That and Trex cam I would say is the largest off the self cam you can buy.
Old 03-19-2012, 03:38 PM
1gt2nv's Avatar
I would also change the fuel injectors, timing chain and oil pump. And do the trunion upgrade to the rockers while your in there. But Bigger isn't always better.
Old 03-19-2012, 03:39 PM
Turd Gen Guy
1nasty86's Avatar
trex or polluter
Old 03-19-2012, 04:44 PM
Petersen's Avatar
I have the ms4 with stock 853 heads. On my 00 trans am can't complain with the gain
Old 03-19-2012, 07:30 PM
Thumper28's Avatar
I haven't come across a person yet who will say that you should keep your stock springs with a new cam. I just posted this on a different thread but it might help you out:
I am putting a new cam in a rebuild right now and I found I have found 2 budget friendly options, one from Lunati and one from Trick Flow. Both are Pacaloy beehives (I'm pretty sure they are the same spring) and I can get either for $129. I know there are better springs out there but these are recommended with the 2 cams that I am trying to decide between and I can still reuse my stock retainers.
Old 03-19-2012, 08:20 PM
ktm8125's Avatar
Ok does anyone know wat the valve clearance it for the stock heads?
Old 03-19-2012, 08:46 PM
badazz81z28's Avatar
I would imagine alot! The stock duration is barely 200 and lift at .500
Old 03-19-2012, 09:54 PM
HoLLo's Avatar
Valve springs are the only MANDATORY item. I'm running stock pushrods on my Patriot cam, over 20k miles on cam, 110k miles on motor. No issues.
Old 03-20-2012, 06:52 AM
redtan's Avatar
Megadeath, will work great in your setup.
Old 03-20-2012, 07:45 AM
b16acrx1988's Avatar
https://ls1tech.com/forums/generatio...cam-guide.html
Old 03-20-2012, 10:02 PM
garygnu's Avatar
you will also need a high rpm converter and a good tuner.I would also install comp trunnion bearings if you use the stock rockers.stock push rods and stock springs only work with stock gm cams.consider a gm ASA cam.
Old 03-21-2012, 11:43 AM
Cstone812's Avatar
Just throw in the ms4...you dont need springs or rods or anything just the cam it will be fine
Old 03-21-2012, 11:50 AM
torkls1's Avatar
^That's funny, but you should have said you were kidding... someone might actually try to do that. Haha.
Old 03-22-2012, 04:31 PM
smg267's Avatar
I'm with you I have been running a .650 lift cam for 3 years over 25k miles stock everything. Push rods and springs are a scam to inflate the cost of a "cam swap". There is a reason they call it a cam swap!!
Quick Reply: biggest cam stock heads
