Can I run the 918 springs?
I just got a new cam with a 595 lift, and I don't know if I should use the 918 springs (I already have them) or go with a dual spring. I don't to spend the money, because my wife will kill me. So I would like some more info on the 918 springs.
Thanks
Nick Watson
Thanks
Nick Watson
SN95 Director
which cam is it, if its an aggressive XE-R-esque cam with high duration i'd consider dual springs. but if your tight on money im pretty sure the 918's will be fine. the PP dual spring kit though is only 300 bucks and im sure you can find a sponsor that carries them thats having a 10% off or some kind of deal to get them even cheaper. just make sure your wife doesnt know
SN95 Director
Originally Posted by nick watson
Thanks a lot for the info,, the cam I am going with is the TSP Custom 231/237 Cam: 231/237, .598"/.595", 112 LSA
I think you will be fine with the 918/titanium retainers. Me personally I like to use double springs but that is because they will probably last more than 20K miles. A friend of mine has that same exact cam you are getting and he is using the comp 918's with it. It is working great for him so far. Good luck
Jimmy
Jimmy
LS1Tech Administrator
Received 1,793 Likes
Jimmy
Jimmy
I'll keep mine for 40-50K.
Originally Posted by RPM WS6
Where did the idea come from that 918s will not last past 20K miles? I can't speak for a BIG cam, but I know of more than a couple people using 918s for well over 30K without issues on moderate sized non-"R" grind cams.....
Jimmy
A lot of people recommend to change them every 20K miles. Do a search!
Jimmy
Jimmy
