G5x2 owners
Old 03-25-2004, 09:41 PM
robiferretti's Avatar
Default G5x2 owners
What injectors are you running with the g5x2 cam (ported or stock heads)??
Old 03-25-2004, 09:46 PM
snake_charmer's Avatar
G5x2/112
Ford 30# SVO's <-- This was recommended by Lou when they did the install.
Ported Ls6 Heads
Old 03-25-2004, 09:57 PM
8 SEC SLOPPY SHOT!!!
tuff's Avatar
Originally Posted by snake_charmer
G5x2/112
Ford 30# SVO's
Ported Ls6 Heads
Svo's 30# seem to do the trick
Old 03-25-2004, 09:58 PM
01_SuperSlow's Avatar
stock heads, stock injectors
Old 03-25-2004, 10:06 PM
MeanWS6's Avatar
lucas 42.5/lb injectors
Cartek Stage II-X heads
G5x2 on 112 LSA
i have AS 5.3 stage 2 heads, vararam intake full bolt ons and the g5x2. Should I upgrade my 28 lbs injectors?
Old 03-25-2004, 10:12 PM
Why don't you give LG a call?
I'm sure you'll get the best advice from them.
Old 03-25-2004, 10:14 PM
tuff's Avatar
A ford injector is really 36# at 58 psi of fuel pressre
Old 03-25-2004, 11:10 PM
Beast96Z's Avatar
Big heads and cam are at the breaking point of stock injectors. I'm sure the duty cycle is getting pretty high. Personally, I would go with the SVO 30lb'ers.(act like 36lb'ers on our fuel pressure)
Old 03-26-2004, 12:26 AM
BurnOut's Avatar
See snake charmer's answer.
Yes, I would upgrade.
Old 03-26-2004, 10:11 AM
CamM's Avatar
I upgraded to SVO 30#...if you have a 99 or 00 car, I would definitely upgrade
Old 03-26-2004, 07:02 PM
i just snagged a set of new 30# injectors off ebay buy it now for $200, i'm a happy camper
Old 03-26-2004, 07:32 PM
Ben01C5's Avatar
This is the first I heard of needing an injector upgrade with the G5X-2. I am in the market for heads now. Will I have to start looking for 30#ers as well???
Old 03-26-2004, 08:32 PM
Unusual T/A's Avatar
I used the stock injectors. I see no reason to add new ones.
Old 03-26-2004, 08:54 PM
CamM's Avatar
If you get just the cam, don't upgrade the injectors. With Stage 2 heads, I would highly suggest it.
Old 03-27-2004, 02:24 AM
you can pick up injectors on ebay, i saw a few auctions for them fairly cheap. Mine i did buy it now and got them for $200 new.
Old 03-27-2004, 02:31 AM
horist's Avatar
i'm running 42lb FMS injectors... but I'm running a bit more than just that cam hehe
