Idling tsp's 231/237 cam on stock tune
has anyone gotten it to idle enough to drive the 50 miles to my nearest shop without using edit? Im going to be installing my heads/cam this coming weekend and would like to know...some have said just disconnect a vacuum source or possibly disconnect the maf but nobody has concretly said "ok this will work" so anyone? Or am i gonna have to be the first to try this lol. Thanks
Bill
Bill
Restricted User
No need to let it idle, install, let it run long enough to get to full temp. Shut off. Check all fluids, I usually change oil at this point. Let cool off all the way if using new springs, that gives them a full heat cycle. Then start back up in the morning, foot brake it if needed and drive it to the shop. If you dont touch the gas at all after install, it should idle fine, but once you touch the gas pedal, well, its going to want that tune! Mine didnt buck to much, but I was tuned for a TR224 cam already, so that helped. If you haevnt done it already, drill the TB blade a little might help also.
lata
Bill
Originally Posted by Ragtop 99
don't drill the TB hole very much; it's hard to undrill it once you tune it
You can turn the idle set screw by 1 - 2 full turns. This will also let more air in and is easily reversed.
I have it in my car and it started on the 2nd. turn of the key and once it started it never died. You should be fine. I drove a while on the stock tune. I have an M6 though.
