5 angle valve job?
Old 04-20-2012, 10:05 AM
Rise of the Phoenix's Avatar
Default 5 angle valve job?
Can anyone explain the beneftis of a 5 angle valve job on the intake side of some 243's. Brett at Land Speed offers a 5 angle race valve job on his stage 2 and 3 243/799 heads. Is that common? I've heard of 3 angle valve jobs, but not 5.
Old 04-20-2012, 10:40 AM
3rdCoastPowerSports's Avatar
5 angle valve job is typically used in racing application. a 5 angle valve job is, well how do you say it... badass
Old 04-20-2012, 11:20 AM
The Scammer Hammer
dr_whigham's Avatar
And that's the exact opposite from what I heard. I was told a 3 angle is for racing, and a 5 was for the street....
Old 04-20-2012, 12:28 PM
Can someone explain to me what a vlave job entails?
Old 04-20-2012, 01:38 PM
KCS
Moderator
KCS's Avatar
A good valvejob is more about the angles than the number of angles. The extra angles are typically both under the bottom cut, and the number of angles doesn't necessarily make it only for a street application or race application. That would be more of a result of the angles themselves.
Old 04-20-2012, 03:39 PM
Good info there. Thank you. Do you know the number of angles the typical 243/799 head porters do; i.e. AI, TEA, TSP, etc.?
Old 04-20-2012, 04:07 PM
KCS
Moderator
KCS's Avatar
It depends on the company, the extent of work (ie stage 1/2/3), etc. Four angles are actually very common, where they will come in with a 3 angle cutter (top, seat, and bottom cuts) and then come back with a 70-75 degree bowl cut.
Also, exhaust valvejobs can have twice as many angles as the intake in some cases.
Check out Newen's profiles:
http://www.newen.com/assets/PDF/TRAD...%20ENGLISH.pdf
Old 04-20-2012, 05:42 PM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
It doesn't really matter the number of angles as much as the angles themselves! And you rarely, if ever, see or hear any head porter share their data.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 04-21-2012, 12:19 PM
well Matt since were talking about secret recipes and you know a boat load about this stuff... can you share some angles of cut with us? maybe some common high pro street angles vs some racing angles. all i know is there is ALOT of power available in a great valve job
Old 04-21-2012, 02:14 PM
The Scammer Hammer
dr_whigham's Avatar
I posted a similar thread a week ago and got "nada" from anyone......
https://ls1tech.com/forums/generatio...rees-cuts.html
Old 04-21-2012, 02:38 PM
gtotoocool1's Avatar
go on Speedtalk.com..there's some info on there,i believe.
Old 04-21-2012, 03:02 PM
studderin's Avatar
One has 2 more angles, thats it.
Old 04-22-2012, 07:04 AM
KCS
Moderator
KCS's Avatar
I'd have to disagree, those two extra cuts can make a big difference in some cases. Of course, it depends on many variables throughout the induction path, but it can be of significant benefit.
Quick Reply: 5 angle valve job?
