Ring gaps. What would you run?
Lost my Mahle sheet on ring specs and had no luck finding info on web. I called Mahle and the tech said run it @
.020 on both the upper and lower rings. Looked more on web and getting a few different answers/ideas so I just am looking for additional information. Motor is stock crank with 3.903 pistons. Thanks.
Moderator
Street/hi performance Bore x .0045". 2nd ring .004-.008 larger than top ring
Drag racing/road racing Bore x .005". See above
Turbo/nitrous Bore x .0055". See above
Oil rings min .015 do not file.
Taken from cp' s site but its the formula I always use when fitting rings.
