ARP Head Stud Instructions
Old 04-23-2012, 08:00 PM
badazz81z28's Avatar
Default ARP Head Stud Instructions
I'm seeing inconsistencies with ARP instructions. I was told the torque for the nuts is 80ftlbs, but someone a while ago said the torque was less for an Aluminum block. Does anyone have their instructions handy?
ARP website doesnt have specific instructions for 234-4317, they seem to be general.
Old 04-23-2012, 08:27 PM
JPH
JPH's Avatar
wHAT HEAD GASKETS?
Old 04-23-2012, 08:36 PM
Mls gm
Old 04-23-2012, 08:55 PM
S10xGN's Avatar
You went here and typed in the part number? This pulls up a PDF sheet for those studs. I don't believe the torque factor will be any different for steel vs aluminum heads and/or blocks...
Old 04-23-2012, 09:13 PM
Yes, I did look there. But like I said, I read an old thread where someone said their actual instructions showed a lower torque for aluminum because of the expansion rate.
Old 04-23-2012, 10:01 PM
01ssreda4's Avatar
These are correct and current:
Old 04-24-2012, 01:19 PM
427LS7HCI's Avatar
I torqued a stud to 80lb and stripped a thread in my block a few months ago and had to order that Kent Moore repair kit. I had spent 2 days prior cleaning those threads in the block.
I have only my studs torqued to 72lbs ft.
Old 04-24-2012, 02:23 PM
Originally Posted by 427LS7HCI
I torqued a stud to 80lb and stripped a thread in my block a few months ago and had to order that Kent Moore repair kit. I had spent 2 day prior cleaning those threads in the block.
Ahh man! Thats scary!
Old 04-24-2012, 09:37 PM
S10xGN's Avatar
Surely you weren't torquing the stud into the block, right? The studs go in finger-tight. If you pulled the block threads while torquing the NUT to 80 ft-lbs, either your wrench was off or the threads were weak.
Old 04-24-2012, 10:06 PM
Received 3,369 Likes on 2,085 Posts
If you cleaned those threads with a tap, verses a cleanup tool, you were removing metal. 2 days worth of cleaning...yikes.
Old 04-25-2012, 10:36 AM
427LS7HCI's Avatar
I placed all the studs in finger tight and I was torquing the nut on the stud. Torque Wrench was brand new and already calibrated. Either way, I felt more comfortable torquing to 72ft-lbs than 80 afterwards.
My sole purpose for purchasing the Studs were to aviod a stripped thread inicident, but it stripped anyway
Old 04-25-2012, 10:44 AM
427LS7HCI's Avatar
Cleaned the threads with a chaser from arp.
I used a vaccum with a straw on the end to suck the coolant out the holes, then I used an air compressor to blow out the holes, then I used twisted papers towels to clean the bolt holes, then I used a .45 bore caliber brush to clean the holes, then I blew them out with compressed air again and then I ran a chaser down each hole. I used a flashlight while cleaning to make sure there was absolutely no crud in there, in which I was very meticulous and the entire process was very time consuming as I spent 2 days (4hrs each day) cleaning those bolt holes.
Quick Reply: ARP Head Stud Instructions
