EITHER Bad Rings or bad valve seals right???????????
Old 04-26-2012, 03:56 PM
LSXFEIN's Avatar
Originally Posted by conan
Your pistons look cleaner than i would have expected to see. It looks like you have GMs MLS head gaskets. Can you find a casting # on the heads ? I would take your heads to a machine shop and let them clean and inspect the heads. Replace the valves seals, check the guides, and let them vacuum test the heads..
yessir at the shop already going to replace all guides and seals. yes the head had a badge stamp (806) im going to post the pics.
Old 04-26-2012, 04:00 PM
LSXFEIN's Avatar
[IMG]
Old 04-26-2012, 04:01 PM
LSXFEIN's Avatar
Old 04-26-2012, 09:44 PM
conan's Avatar
Hope this takes care of the problem.
What size was the block honed to ? 3.903 3.905 ?
http://www.texas-speed.com/p-2274-gm...ad-gasket.aspx
http://www.texas-speed.com/p-205-gm-...er-gasket.aspx
Talk to them about thickness between the 2 gaskets to get the best for your setup.
Old 10-11-2014, 03:57 PM
lq4240sx's Avatar
Did you ever figure out this issue? Mine is doing this right now.
No pcv connected at all and oil on top of every intake valve
Old 10-11-2014, 09:17 PM
LLLosingit's Avatar
The answer is right in the post>>>>. Bad seals and guides. Bad or incorrectly installed valve seals let oil drain down between the valve guide and stem where is accumulates on the valve.
Old 10-14-2014, 02:39 PM
lq4240sx's Avatar
the issue I'm having is different then. but I maybe have installed too small of a head gasket. I've got afr 230 heads and put ls9 (4.100 bore) gaskets on the setup. AFR says the minimum needed it 4.125 and recommends 4.135
Quick Reply: EITHER Bad Rings or bad valve seals right???????????
