TRex w/ Decked 243 heads
Old 04-27-2012, 12:36 AM
Rangersltw's Avatar
Default TRex w/ Decked 243 heads
I have a TRex cam 242/248 .610/.615 110LSA. I am pulling my 241s and replacing them with 243 heads.
edit: I am thinking I will be getting them milled .036 to achieve a 11.1:1 CR How much should I fly cut to maintain proper PTV clearance?
Old 04-27-2012, 02:00 AM
TransAmcoupe98's Avatar
I dont think you will have clearance if you mill them without flycutting your pistons. Out of curioisty, what gear are you running with this cam?
Old 04-27-2012, 02:03 AM
Rangersltw's Avatar
I know I wont. That is why I said I was fly cutting them. My question is how much should I fly cut them. I am running 4.30 gears w/ a 9in.
Old 04-27-2012, 02:14 AM
Oh I apologize, I didn't see that part. I have some info I'll post in a few. Those gears will do nicely with that cam.
Old 04-27-2012, 02:17 AM
Rangersltw's Avatar
Thanks! I currently have 4.10s with my 10bolt now. Its just not enough. Im still waiting on my MWC 9in. It should be done soon.
I want to say that .1'' is about as deep you should go safely. I couldnt find specifics on the t-rex, but I don't think you would need to go that deep.
Old 04-27-2012, 03:00 AM
Rangersltw's Avatar
I have the cam specs posted in the OP.
Old 04-27-2012, 03:11 AM
I meant about how much is the norm people are flycutting using the t-rex. Give thunder racing a call, they have pretty good CS.
Old 04-27-2012, 03:16 AM
Rangersltw's Avatar
I just had a thought. If I am not having clearance issues now and then get the heads milled .036. If I fly cut at least .036 Wouldn't that be the same clearance I currently have?
Old 04-27-2012, 04:18 AM
Not necessarily. I dont know how much clearance you would have with that cam on unported heads. If you had any, wouldn't be much at all, not safe enough in case of an over rev.
Old 04-27-2012, 04:21 AM
PREDATOR-Z's Avatar
Even in stock setups the margins are below recommended operation. Will the Trex clear milled heads? NO
You should flycut .080 or 2cc
Old 04-27-2012, 04:22 AM
01ssreda4's Avatar
I find out the max that's safe to cut a stock piston and cut it that much.
EDIT: or just listen to predator's suggestion.
Old 04-27-2012, 05:20 AM
mark21742's Avatar
Bolt them on and clay them.....take what you find and subtract .040" and that will tell you how much you need to cut the pistons to be safe.
Since your bumping up your compression go with a .40" gasket too...stock pistons come .005-+" up out of the hole, so this will give you your optimum quench area and help keep knock down if you get a bad tank of gas
Old 04-27-2012, 06:56 AM
2000whitevert's Avatar
Lift is not the only thing that should be used to determine ptv clearance. Cam timing events are a big part of this. I agree with claying your set up to be certain. As with any engine modification checking clearances is the only insurance to avoid a problem.
Old 04-27-2012, 08:47 AM
Rangersltw's Avatar
I already have a stock GM gasket for replacement. What is OEM thickness? Will having the .40 gasket make that much difference? I will be claying. I'll cut them to .080 and check ptv.
Old 04-27-2012, 08:55 AM
mark21742's Avatar
Stockish .051". Since you already have them, run them...but if you end up pulling your heads again later and needing more gaskets, pick up the .040"
Old 04-27-2012, 10:04 AM
BuckaroooZ28's Avatar
T Rex hit my stock 241 valves.....self clearance lol
Old 04-27-2012, 12:17 PM
PREDATOR-Z's Avatar
When does max lift occur???? Contact is probable from 10* BTDC to 10* ATDC. So lift (at the range we use) have little to do with PTV clearance. Do not confuse with tappet lift.
Old 04-27-2012, 01:14 PM
95ONE's Avatar
If you're going to cut that much off the deck, don't forget to get the shorter Push Rods while you're in there. My new pushrods needed to be shorter by the exact amount I milled the heads also subtracting the .01 for the thinner headgasket from stock thickness.(Not exactly shocking) - in your case, .050 shorter. ( .036 milling + .010 thinner gasket = .046) I suggest starting there.
.080 on Intake. .10 on exhaust. - Exhaust expands more with more heat is the reason. I bet you're already too close to the pistons and just haven't hit yet. If you're heads are going to be off. Don't be lazy. Clay the pistons and KNOW what you need to do.
or just slap those puppies on there and GO! There's always a choice.
Old 04-27-2012, 02:04 PM
Rangersltw's Avatar
My overall goal with decking the heads is to be around 11:1 CR. How can I figure out how much I will lose with fly cutting? I will be claying the pistons to check for PTV.
Quick Reply: TRex w/ Decked 243 heads
