Mis-shift leads to more work. Head Removal Help
Old 03-29-2004, 11:13 AM
Z28Venom's Avatar
Default Mis-shift leads to more work. Head Removal Help
Well..
This Sat at the track I went 1-2-3 and back to 2... I thought that I had killed my car. Now it has a very noticable tick. I rev it a little and the tick stops, but once the engine gets back to idle the tick comes back.
I was already in the process of getting things together for my cam install. I guess that I'm gonna have to pull the heads also. So that I can check to make sure that I didn't bend any of the valves.. I was planning to change the pushrods w/ TR Hardened ones. I'm pretty sure that I may have bent them.
Does anyone have a link to a head removal how-to? Or is this something that should be done by a professional?
Old 03-29-2004, 01:31 PM
93octane's Avatar
I would check out the write-up on www.ls1howto.com
Here is the direct link to the heads/cam swap that will help you in taking the heads off:
http://www.ls1howto.com/index.php?article=2
GL - hope it's just a PR and not a valve.
Old 03-29-2004, 01:32 PM
DenzSS's Avatar
Just remember that if a pushrod doesn't bend, something else will.
Pushrods are cheap.
Old 03-29-2004, 03:03 PM
Restricted User
CAT3's Avatar
Since your in Hawaii, you are in HI right? Might want to get ahold of Joe (mustang), he has some friends I hear that do cam swaps and other stuff like that. One might even have a good cam /heads combo for you to pick up cheap! gee how'd I know.
And I just told Joe the same thing, the stock pussrods are your savior, if not the lifters would **** and mayeb the valves!
Old 03-29-2004, 03:06 PM
ducati916's Avatar
if they dont bend what else will break.....springs, valves?
Old 03-29-2004, 03:10 PM
DenzSS's Avatar
You'll collapse a lifter or take out a valve stem. Either is bad, valve stem can be terrible.
Old 03-29-2004, 03:12 PM
Restricted User
CAT3's Avatar
Yep, the stock pussrods are a angel for some of the M6 guys.
Z28Venom's Avatar
Alright.. These are my symptoms:
Car doesn't idle rough or anything. Drives normally also. There is just slight ticking sound that seems to be coming from the drivers side right at the front of the door. It also seems to coming from the lower portion of the engine near the headers...
any guesses?
Old 03-29-2004, 03:14 PM
Restricted User
CAT3's Avatar
Yes, either a bent pussrod, not uncommon for the description or an exhaust leak. I got a set of stockers at home. Joe knows the guys that can get them for you-free! Just let me know on here and I will call them as I am sitting in NY on leave before I deploy.
Old 03-29-2004, 03:18 PM
DenzSS's Avatar
Just remove the coils, remove the valve covers, remove rockers.
remove each pushrod one at a time. After removing the pushrod, roll it across a piece of glass or a mirror. If anything rolls oddly, it is bent.
Check all of the pushrods and replace any that are bent.
Do them one at a time so you can keep track of what valve and cylinder the pushrod came from. If a cylinder has a bent pushrod, visually inspect rocker, valve stem, and everything else you can see.
If you find no damage other than the pushrod, reassemble and go on your way.
Old 03-29-2004, 03:21 PM
Z28Venom's Avatar
What's up.. Cat
I work with Joe.. I believe he was posting this on insayne stangs too..
I already have the parts for my cam install.
TR230/224 .575/.563 111LSA
TR Hardened Rods..
Comp Cam 918 Springs
Comp Cam TIT Retainers..
I was just wondering if I should remove the heads and check the lifters while I do my cam install.
He also doesn't believe that I'll put down a 12.9 when my ET Drags get here.
Old 03-29-2004, 03:25 PM
AsianIce25's Avatar
Ive misshifted like you before, but i caught mine before it actually overrevved. Id suggest what these guys are saying too. my car ticks too, but not bad, and its done it for a long time. oh well...
Old 03-29-2004, 03:27 PM
Restricted User
CAT3's Avatar
Like I told him, keep missing the shifts, you wont. Just do yourself a favor, pull the above directions onto a printer, and follow them, see which ones are bent. If they arent any, then you can spend the extra $$$ for the lifters/valves. Just to easy. Wont cost any $, you pull covers, loosen rockers, pull Pussrods, roll on glass and replace as needed. Tighten back down and go.
Old 03-29-2004, 03:40 PM
Z28Venom's Avatar
Oh yea.. can I get the contact info for whoever has the free stock pushrods?
Old 03-29-2004, 03:44 PM
Restricted User
CAT3's Avatar
sure. call me, but leave a voicemail. 277-7246. or call joe, he can get in touch with Pat who can get to my stockers tonight for you. If you go with him, you can check out another addition you may want to pick up. I dont have joes # sorry.
Old 03-29-2004, 03:50 PM
Z28Venom's Avatar
Alright.. I'll just have Joe contact Pat for me, and see when would be a good time for him to do that. What's this new addition that you're speaking of?
Old 03-29-2004, 03:53 PM
Restricted User
CAT3's Avatar
Pat can show you.
How would like to bolt that cam in, and an additoinal say 50rwhp? Sound good?
Old 03-29-2004, 04:01 PM
Z28Venom's Avatar
a set of HEADS?
