Checking PTV confusion
Old 05-18-2012, 08:45 AM
badazz81z28's Avatar
Default Checking PTV confusion
I have a feeling I will hear crickets on this one....
Ok, I read a thread about checking PTV clearence with a sold lifter.
My question....How do you use your stock pushrod? If my pushrods are measured with zero lash + .05-.08 pre-load, with a solid lifter, my valves will be pushed open that much reducing the measured clearence.
Does that make sense? Seems to do this right, you need different (Shorter)pushrods?
Old 05-18-2012, 09:49 AM
mark21742's Avatar
You are looking for a MINIMUM of .080" on intake, and .100" exhaust, so if you get your measurement in the clay and add your preload of .050-.080" to it that should give you your ptv.....to be safe I'd only add the minimum of .050" to your clay measurement.
Old 05-18-2012, 10:51 AM
Any tips on where to buy a single or pair of solid lifters?? (Cheap)
Old 05-18-2012, 11:02 AM
mark21742's Avatar
If you have an old junk one you can pull it apart and put a gob of rtv in it, put it back together and come back tomorrow and it will be solid
Old 05-18-2012, 01:43 PM
I dont have any old ones...Im new to ls engines
Old 05-18-2012, 02:08 PM
mark21742's Avatar
Any 87 up roller rockers can be used as a single.....might even be able to get just one from a local parts dealer......wish you lived close to me I'd dig around find an old one for you
Old 05-19-2012, 06:57 AM
redtail2426's Avatar
you dont need a solid lifter if you use a checking spring and adjustable pushrod,you can use a toilet paper holder spring too
Old 05-19-2012, 07:17 AM
PREDATOR-Z's Avatar
You use an adjustable p-rod checker at 0 lash on base circle of cam. Then you remove it and add desired pre-load.
bingo that is your p-rod length desired.
Sometimes I use 2 size p-rods if the cam is dual lobed. So intake will be different than exhaust.
Old 05-19-2012, 04:35 PM
ABQ99TA's Avatar
Interesting! On my last build I noticed that the intake looked like it wanted a .025 longer PR but I thought I was crazy and used the same on both. I will be making some changes to that motor in the next few weeks maybe I will order the longer ones for the intake.
