critique my build and what hp can i expect
ok guys i have a bone stock ws6 and want to mod it so this is want i am thinking about
1. tsp stage 2.5 5.3 litre heads
2.ms4 or t-rex
3.scoripion rockers
4.mwc for 9 inch
5.4.56 ring and pinion
6. umi sfc, rear lca's, phb, torque arm for the rear also with relocation brackets
7. front upper tubular control arms, lower tubular control arms, front qa1 coilovers also i will be doing wheel bearings while i am in there
8.also flush the coolant system, change thermostat
9.also kooks long tubes, with gmmg cat back
10 also looking to put some jug on the car
i will be doing all the work myself even the tune anything i forgot or you guys have tried and has worked better and was wondering can i get this combo into the 400whp range
2.ms4 or t-rex
3.scoripion rockers
4.mwc for 9 inch
thanks it an m6 i will deff do the ls6 intake i rode in one with the asa hott cam and got the bug but i want a max effort street/track car
shooting for high tens with the bottle plugged in
I feel the yella terra rockers would be more stable with a big cam .what intake will you use ?if you plan to run NOS get some 3.73 gears.you will need a better fuel pump and bigger injectors.do a nice flowing Y-pipe with a 4" I pipe .
I'd go with CHS 5.3 heads hands down. And PM me I have under drive ASP pulley for sale, hooker jet hot coated super comp headers andoff road y-pipe with cutouts installed. BMR k-member and other stuff.
Those heads will not accept Trex. Do it right and flycut pistons.
The biggest mistake people make is just slap a bunch of parts together and think it is going to fly.
First of all, what is your budget?
Budget is 6500 I want a tubular k member I am lOoking for a respectable street car and I have the fly cutting tool also thinking about gas porting the pistons I am leaning towards a custom nitrous cam from bullet I thank everyone for there inputs
