Do I have this right? (preload)
Old 06-04-2012, 10:14 PM
nvr enough's Avatar
Default Do I have this right? (preload)
I'm running morel lifters with stock rockers and 7.4" pushrods..I get 1-1/2 turns to torque (22lb) when checking preload. Do I have the correct length pushrods?
The more I read about checking preload, the more confused I get.
Thanks in advance.
Old 06-05-2012, 11:04 AM
LS1Tech Premium Sponsor
Sales2@Texas-speed's Avatar
Which morel lifters are you running so that we can see what the recommended preload is for them? You're at about .076" or so of preload currently, assuming that was 1.5 turns from zero lash.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
Old 06-05-2012, 06:23 PM
vettenuts's Avatar
You may have too much. The Morels I am running require 0.030"-0.050" preload.
Old 06-05-2012, 10:07 PM
nvr enough's Avatar
After finding, and googling the part number, I found I'm running the "street" morels (5290's).
Although I can't figure out the math aspect, from what you guys are saying, my pushrods are a little to long, right?
I appreciate your responses.
Old 06-06-2012, 04:42 PM
nvr enough's Avatar
I've been trying to figure out the math, but I still don't get it. I don't see how you guys are doing the math?
Should I sell my 7.4's, and get some 7.375" pushrods?
Old 06-06-2012, 06:29 PM
Darkman's Avatar
The math is discussed in this thread:
https://ls1tech.com/forums/generatio...re-load-2.html
Old 06-06-2012, 10:04 PM
Monte4ever's Avatar
Thanks in advance.
It looks like you are adding the total amount of turns that it takes for you to reach your torque value to your preload count which is not the correct way. Preload on a LS based motor is when the rocker arm makes light contact with the pushrod while its resting on the lifter seat. Then watch how many turns it takes for the rocker arm bolt to stop turning BEFORE you apply torque to the bolt. If I'm wrong in my assumption then sorry lol.
Old 06-07-2012, 01:34 AM
nvr enough's Avatar
Thanks.
So if I'm at .076 preload now roughly, and .050 seems to be my target, a 7.375 pushrod should put me at about .051...correct?
Old 06-07-2012, 01:37 AM
nvr enough's Avatar
I'm going by what this says...but the way I read it, makes me think it's the total amount of turns it takes to reach 22ft. lbs., after reaching 0 lash
1. Using the EO/IC method, get the lifter to the base circle of the cam.
2. Using a known length pushrod (7.400" is a good start with stock rockers) run the rocker arm bolt down to zero lash. This is easily done with your fingers "wiggling" the rocker, the point at which the "slack" is just gone is zero lash.
3. Set your torque wrench to 22 lb./ft. Tighten the rocker to full torque and count the number of turns it takes to get there. 1 full turn wtih a stock 8mm X 1.25 bolt is ~.047" preload as measured at the pushrod/rocker interface.
4. I normally shoot for 1 1/4 to 1 3/4 turns with stock type lifters like Comp 850's, LS1, LS7 etc.
For an example, if you use a 7.400" pushrod and come up with 3/4 of a turn, you will need at least .025" longer pushrod to get into range. If you end up with 2 1/4 turns, you will need one .025" shorter...
Old 06-07-2012, 03:54 AM
vettenuts's Avatar
The counting turns method isn't real accurate, but based on Shane's posts and my verification with a dial indicator, you need one turn from zero lash to 22 lb-ft. Morel's don't like too much preload and will hold the valves open if they have too much, so it would be best to measure and make sure of your preload.
Old 06-07-2012, 06:21 AM
Darkman's Avatar
Thanks.
Using your measurements and the corrected math for the number of turns (see the other thread), your current preload is about 0.091 with the 7.400 pushrod. Since Morels use a preload of 0.030 to 0.050, you presumably need a pushrod of 7.339 to 7.359. A 7.375 pushrod would put the preload at 0.066 which is too much. A 7.350 pushrod would put the preload at 0.041 which is in the middle of the range for Morels.
Old 06-08-2012, 12:26 AM
nvr enough's Avatar
okay. thank you all for your help.
Old 06-11-2012, 11:43 PM
nvr enough's Avatar
I picked up a set of 7.350 pushrods, and double checked my preload on a couple different cylinders (I only checked one the first time). I get 1-1/4 turns on some of the bolts, which if I'm understanding this correctly, puts me over .050 preload...and in doing some reading, I'm running an iron block/aluminum head combo which should even have a little less preload.
You guys think I should I take these 7.350's back and get some 7.325's? Or just run these 7.350's?
Quick Reply: Do I have this right? (preload)
