Valve cover gaskets not fitting....
Old 06-27-2012, 06:35 AM
streetknight2's Avatar
Default Valve cover gaskets not fitting....
Am I doing something wrong lol? Tried Fel Pro and these are GM, like they're a tad too long.
Old 06-27-2012, 06:44 AM
ss4chad's Avatar
Are they used gaskets or new? In either case just stick them in the freezer for about 30 minutes, this will shrink them considerably and they will fit just fine.
Chad
mark21742's Avatar
They can be a pain, it will fit, you just stretched it out....keep working it a squeeze it in place
Old 06-27-2012, 06:55 AM
They're new, just pulled that one out of the pack, started it at the 3 humps and worked it around. I'll give it another try, thanks
Old 06-27-2012, 08:43 AM
mark21742's Avatar
You will probably have to push it back and forth a little and try to compress it in the lock groove, but it will go in
Old 06-27-2012, 11:18 AM
ss4chad's Avatar
Freeze it, then put it in.
Chad
Old 06-27-2012, 11:19 AM
Thanks, freezer trick worked great
Old 06-27-2012, 04:02 PM
ss4chad's Avatar
Chad
Old 06-27-2012, 10:37 PM
mark21742's Avatar
I always fought them in...I'll have to remember the freezer trick!
Quick Reply: Valve cover gaskets not fitting....
