Camshaft Help ( PVT ) Clearance
Old 06-27-2012, 08:33 PM
Bama99z's Avatar
Default Camshaft Help ( PVT ) Clearance
Been speaking with several camshaft companies about options. However they are all over the board on suggestions. So I thought that I would ask here and see what ya'll would recomend with my set-up. I dont want to have to worry about the old dreaded ( PVT ) issue.
Car is a 1999 Z-28 Stock motor.
1 3/4” ORY With hooker cat back.
Trans Auto with a PTC 3600 Lock-up convertor
rearend gear 3:42 I am almost 100% sure
Intake Fast 90 With a Nick Williams 90 TB
Heads are Patriot Performance Stage 2 P/N 2033
These heads provide up to a 65 cfm improvement over stock OEM versions. The 59cc chambers, will increase the compression on a stock LS1 from 10-1 to 11-1 Original Patriot Gold Dual .650” Lift springs, titanium retainers, Super 7 machined locks, custom honed bronze guides, machined spring bases, and viton rubber seals.
Thanks for all of you help.
Old 06-27-2012, 08:55 PM
hotrodth's Avatar
Id say a 224-228 from tsp. You won't be able to go very big with chambers that tight.
Old 06-27-2012, 10:12 PM
Bama99z's Avatar
Default 59cc
So are you saying the 59cc chamber head's are hurting me more that helping?
Old 06-28-2012, 03:42 AM
hotrodth's Avatar
No not at all. More compression=more power. Bigger cams aren't always better anyway. If you want a bigger cam you may have to flycut pistons. You want a minimum of .060 ptv clearance.
Old 06-28-2012, 04:10 AM
bww3588's Avatar
Min .080 intake, .100 exhaust.
Old 06-28-2012, 04:19 AM
hotrodth's Avatar
Min is. 060. .080 is better. But ppl have gotten away with less than 060. But its pushing it. Obviously the more the better.
Old 06-28-2012, 05:50 AM
PREDATOR-Z's Avatar
Fyi .080 is considered tight by professionals on street hydraulic motors.
Old 06-28-2012, 06:03 AM
streetknight2's Avatar
I'd talk to Geoff at EPS and do whatever he says.
Old 06-28-2012, 07:18 AM
bww3588's Avatar
.080 intake, .0100 exhaust. Minimum. Period. Any less and your playing with fire. Stop spreading bad info.
Old 06-28-2012, 10:28 PM
Bama99z's Avatar
Default Clearance
Everyone, thanks fro all of your input. Iam kinda new to the LS1 world.
Streetknight, I actually spoke with Geoff this afternoon about a cam. He actually asked me to check a couple of thinhs on my heads tonight. I did and will be back in touch with him tomorrow.
However, things may of changed a little as of this evening. I may purchase a 6.0 short block and just build it and keep the original 5.7 stock. Not for sure yet though. Gonna sleep on it tonight and decide tomorrow.
Quick Reply: Camshaft Help ( PVT ) Clearance
