Comp Cams: "Don't use Comp-R's" with LS1
Old 04-01-2004, 04:50 PM
Mr. B's Avatar
Default Comp Cams: "Don't use Comp-R's" with LS1
I have Comp-R lifters, and I called Comp and they emphatically stated the "you CAN NOT use Comp R lifters without adjustable rocker arms!
I researched and found everthing from 1/8-1/2 turn.. and also read about .002"-.004"... and yet simply torque to 22ft lbs.
Has anyone used these (with dual springs) without problems.. and if so, what preload?
Old 04-01-2004, 04:52 PM
SPANKY LS1's Avatar
PM Nasty N8, a sponsor on this site, he has set up many with both YT and HS non-adjustable rocker arms with good success, and he'll be setting mine up in a week or two.
Good luck, Shawn
Old 04-01-2004, 04:56 PM
Beast96Z's Avatar
You can use them with non adjustable rockers, but they have to be shimmed to the proper pre-load, which is .002 to .004.
Old 04-01-2004, 05:18 PM
verbs's Avatar
And that sir is almost next to impossible.
After talking to Louis @ LG for a while, he said a common practice there is to slap in some 7.35" pushrods with the comp R lifters, no shimming, and call it a day.
Old 04-01-2004, 05:23 PM
Scalpel's Avatar
My MTI built 427 has the Comp Rs with non-adjustable Jesels. They work great.
Old 04-01-2004, 05:34 PM
LS1TECH Sponsor
Steve Burger's Avatar
I have them with 7.35 PR and a .030 SVO shim. All with HS rockers. Less than 1/4 turn of preload all the way around. It was a little work but seems to be working OK.
Old 04-01-2004, 06:19 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
I have run 2 sets and they work great.
Old 04-01-2004, 08:02 PM
goinbroke's Avatar
Without shimming?
Old 04-01-2004, 08:32 PM
BigTex's Avatar
And when they dont work great, what are the issues? Noisy valvetrain, valve float,????
Old 04-01-2004, 08:35 PM
Beast96Z's Avatar
Busted lifters and low power.
Old 04-01-2004, 08:46 PM
EVIL's Avatar
i have the comp r's and comp mag rockers and i am having valve float issues. we dynoed tonight and it was making good power all the way to 6200, then it fell off.
made 374 thru a th400/4000 stall/9 inch/28 inch hoosiers
might make 390-400 if we can get it to pull to 6800-7000
Old 04-01-2004, 09:21 PM
BB
BB's Avatar
I don't get it - valve float with Comp R and adjustables! What springs are you using?
Old 04-01-2004, 10:10 PM
Senior Member
Country Boy's Avatar
Things have specs for a reason. Try cranking your rod bolts to 200 lbs so they are just good and tight.
I have them, but I also have adjustable rocker arms too. Preload is 1/16th of a turn past 0 lash.
Old 04-02-2004, 12:36 AM
Unaffliated Racing's Avatar
"Things have specs for a reason. Try cranking your rod bolts to 200 lbs so they are just good and tight"
gah..you can tell people a million times..but they still dont listen .002"-.004" means .002"-.004" preload
Old 04-02-2004, 01:34 AM
jerflash's Avatar
i am really looking into a set of these but i just dont know it a sould
with all these problems i dont know it they are worth it
i plan to be reving tho motor out to 6800-7000 so they would be a good idea to have
im just not comrotable with all this preload crap
i here some peoplejust put a .020 shim under the rockers and tighten to 22 ftlbs
and some use shorter pushrods
its just to confusing
Old 04-02-2004, 03:52 AM
GTBMad's Avatar
Running Comp Rs on a 427 with yella terras they can be setup with shimming and stock length pushrods. However would recommend adjustables hell of a lot easier to set up.
Old 04-02-2004, 07:01 AM
BLUEBALLS ZZ's Avatar
weird, i am running the comp R's with a 236 242 cam and no issues gained 3 mph over my 224 cam. went from 118 to 121. valve train is quite as hell. maybe i am just lucky.
Old 04-02-2004, 07:12 AM
Senior Member
I dont get what the big deal is
Old 04-02-2004, 07:20 AM
EVIL's Avatar
crane duals...i have seen it on other cars too, i think we need to back them off a little. this was the first set of adjustables i have ever set up.
Old 04-02-2004, 07:36 AM
michael101's Avatar
I'm having this problem too, but I'm not so sure it's a valve float problem. I'm hearing rumors that maybe the 'r' lifter isn't working so well with cams that have a real agressive ramp.
I've backed my preload all the way to zero but I'm still having the problem around 5500rpm. I'm also running the crane duals and comp pro mags. I had these same springs in the car before the cam swap and had no rev issues at all, and that cam was more lift than my new one.
Quick Reply: Comp Cams: "Don't use Comp-R's" with LS1
