243/799 heads.. Differences???
Old 07-15-2012, 10:14 AM
JustAFooL's Avatar
Default 243/799 heads.. Differences???
Just curious what the difference is in these heads. Always hear about people working 243s but don't really hear much about 799s
Old 07-15-2012, 10:20 AM
wooddaniel's Avatar
They are very similar, I don't think the 799's have the sodium valves and are a little rougher and dont flow quite as well though almost as well. Sure someone else will chime in.
Old 07-15-2012, 10:26 AM
CamaroZ28_LS1's Avatar
same specs as a ls6 head, no sodium valves and no stock ls6 valve springs. That is pretty much it, I run 799 heads.
Old 07-15-2012, 10:28 AM
senicalj4579's Avatar
The head castings are the same.
Old 07-15-2012, 10:41 AM
Sales1@Texas-speed's Avatar
Both are very similar with only minor differences from the factory, but when working them over the process is essentially the same considering they are of the same port design.
Old 07-15-2012, 11:17 AM
The Scammer Hammer
dr_whigham's Avatar
If you have 243's from a 02-04 Z06 or 04-05 CTS-V they will have the hollow/soduim valves.
Any other 243 will have regular solid stem valves. I got mine off a 2010 GM 5.3 truck. This includes LS2 243's as well.
799's are a bit of a rougher casting, but that doesn't amount to a hill of beans if you're porting them.
Here's a bomb-*** set of 799's, FYI https://ls1tech.com/forums/generatio...-cnc-work.html
Old 07-15-2012, 12:02 PM
JustAFooL's Avatar
So essentially if the heads are going to be worked, there is no difference I'm assuming.. It's time to invest in some heads and I found a set local for 175$.. A I will be doing the work.
Old 07-15-2012, 12:05 PM
Thats what I was trying to say. From what I know the casting #s are the same. Differences are the parts used. Thats what I thought anyway...
Old 07-15-2012, 12:14 PM
jerryls7's Avatar
that's a good deal at $175
Old 07-15-2012, 01:04 PM
wooddaniel's Avatar
Yeah that's a steal jump on it
Old 07-15-2012, 03:16 PM
JustAFooL's Avatar
Done picked them up.. now for a question on valve springs. The car currently has a 224/230. .589 lift cam that's been in there for probably about 6k miles. I may keep this cam and mill the heads quite a bit to bump compression.. Do you guys think it would be ok to swap these springs to the new heads or do I need new springs?? By the way, the springs are the prc set rated for .650 lift from tsp..
Old 07-15-2012, 04:13 PM
The Scammer Hammer
dr_whigham's Avatar
Only one way to find out.....
Get them checked at the machine shop. I doubt you've lost any pressure in 6k miles, but stranger things have happened, and there's just too many factors to consider on an individual basis for spring longevity.
You're pulling them anyway.... Just get them checked.
Old 07-15-2012, 05:04 PM
^Agreed, the springs should be in great shape but you definitely want to get them checked out since they will be coming off for the swap anyway.
Old 07-15-2012, 08:19 PM
badazz81z28's Avatar
If you have ever seen a set side by side there are subtle differences. The casting process is different. Notice the "triangle" under the spark plug holes on the 243s. I believe its called "Die Cast" as the 799s and others are sand casted.
Old 12-23-2016, 08:06 PM
cookseyb's Avatar
The design of the heads are the same but the 799 are sand cast and the 243's are investment cast. Bought a TBSS motor that had one each. so GM don't care.
Old 12-23-2016, 08:51 PM
20Silverado03's Avatar
One type of head on each bank? lmao crazy The 243s are equipped with sodium filled valves which are lighter but id imagine both banks have the same valves, springs etc
Old 12-24-2016, 09:34 AM
nobreaks254's Avatar
[QUOTE=dr_whigham;16519961]If you have 243's from a 02-04 Z06 or 04-05 CTS-V they will have the hollow/soduim valves.
READ THIS
Old 12-24-2016, 09:43 AM
LLLosingit's Avatar
This post was from 2012, Must have been searching for something?
Old 12-25-2016, 04:37 PM
KCS
Moderator
KCS's Avatar
Some 243 heads have the sodium filled exhaust valves and hollow stem intake valves, but not all of them. Most have solid stainless steel valves.
Old 12-26-2016, 01:18 AM
thanks for clarifying
Quick Reply: 243/799 heads.. Differences???
