Advanced Induction 226cc CNC work
Old Apr 3, 2012 | 10:34 PM
01ssreda4's Avatar
Default Advanced Induction 226cc CNC work
Got my hands on these, so I thought I would post some pics for those that are interested. Heads had previously had a clean-up mill of about .010 done. Heads have been cut .030 more by A.I. bringing compression on a stock short block to 11 to 1. All flanges were milled smooth also.
Old Apr 3, 2012 | 10:40 PM
SWEET98SS's Avatar
Those look great, kinda like the ones I have. What cam are you pairing them with?
Old Apr 3, 2012 | 10:45 PM
01ssreda4's Avatar
Cam Motion 228/232 .612/.612 113+4
Old Apr 3, 2012 | 11:14 PM
02TransAm/Batmobile's Avatar
Looks like they reworked that bulge where the spark plug inserts. Doesn't that increase chamber size/decrease compression?
Old Apr 3, 2012 | 11:22 PM
nukeemall454's Avatar
Almost the same setup I am looking to do only with a Streetsweeper HT. Would like to see how your car performs when all is said and done.
Old Apr 4, 2012 | 12:16 AM
01ssreda4's Avatar
Look closely, the entire chamber is CNC'd, and yes this decreases compression from the removed material.
Old Apr 4, 2012 | 07:19 AM
*02WS6TURK*'s Avatar
Very nice man. I'm going to be running those same heads at some point down the road. Solid cam choice as well. Looking forward to seeing your results. G/L
Old Apr 4, 2012 | 09:05 AM
Darkman's Avatar
Did you happen to get any flow numbers with those?
Old Apr 4, 2012 | 09:13 AM
96lt4c4's Avatar
What castings are those? Are these going on a stock short block LS1?
Old Apr 4, 2012 | 03:27 PM
01ssreda4's Avatar
Flow numbers are posted on their website I believe. A CNC doesn't have a good or bad day, it produces the same results day in and day out, so those "old" flow numbers would still be valid.
226cc is their 243/799 casting program. These are 799s.
Old Apr 4, 2012 | 03:45 PM
Rise of the Phoenix's Avatar
Did you elect to go with any of the "ugrades" AI offers, or did you simply pay for the CNC work, plus the shipping?
Old Apr 4, 2012 | 03:54 PM
01ssreda4's Avatar
Don't know of any "upgrades".
Old Apr 4, 2012 | 03:59 PM
This:
Bronze Guide Liners installed & honed to ideal clearances to refurbish worn out guides. - Cost: $125
Replace OEM guides with Full Bronze Guides & hone to ideal clearances - Cost: $250
PSI 1511 MaxLife Endurance Spring Kit w/ OEM Replacement Seals. - Cost: $250
Manley 23622 Titanium Retainers for OEM, PAC, PSI, etc. beehive springs - Cost: $195
Lunati Gold dual valve spring kit w/ lightweight steel retainers. Lift capacity to .660" - Cost: $225
Manley 221436 Nextek .660" shot peened & fully polished Dual Spring Kit:
221436-16 Dual Springs
23623-16 Titanium Retainers
42334-16 Hardened Spring Locators
13098-16 Precision Machined Locks
Steel jacketed Viton seals for dual springs
Cost: $525 bought w/ head work (This is a premium setup that is ~$700 shipped from Summit)
Old Apr 4, 2012 | 04:19 PM
01ssreda4's Avatar
My valve guides weren't worn out but if they were then I woulda let them replace them, and yes I had them throw me a set of the Lunati's on the heads before they left.
Old Apr 4, 2012 | 04:49 PM
427LS7HCI's Avatar
I wonder why is it that TSP doesn't port their 799 chambers like this on their LS6 stg 1 and 2.5 heads?? Their chambers are like this:
Old Apr 4, 2012 | 07:06 PM
Camaroking1996's Avatar
How much power are you looking for with this setup? And what intake are you running?
Old Apr 4, 2012 | 08:49 PM
mac62989's Avatar
x2 on what intake. Im going with a 228/232 cam just deciding between these or the 241 HCR heads. When will it be all installed and tuned?
Old Apr 4, 2012 | 09:34 PM
01ssreda4's Avatar
You'd have to ask them. I'm pretty sure they have budget offerings as does A.I. The 226 that is done above is pretty much A.I.'s all out port job for 243/799 castings. All of their work utilizes stock valves as an FYI.
Power? I dunno, likely won't even take it to the dyno. It will go to the track, a bunch, and I have tons of slips before the head swap so we are gonna see the performance gains. My car is very predictable and consistent so it shouldn't be hard to see the gains in MPH and ET.
I'm gonna stick with the LS6/stock MAF/SLP lid at this point. After I get some solid baselines I think I will do a FAST and an 85mm MAF and upsize lid and see where that takes me.
Old Apr 4, 2012 | 10:57 PM
427LS7HCI's Avatar
I was told that the slight roughness actually makes it flow better than a smooth mirror finish
Old Apr 4, 2012 | 11:05 PM
01ssreda4's Avatar
On the intake port some texture helps mix fuel and air, but most will fully polish the combustion chamber from what I've seen. One perk of doing this is very little carbon build up in the head chamber.
