LS1 sat for a year wierd compression when checked
Old 08-04-2012, 03:02 PM
Littered's Avatar
Default LS1 sat for a year wierd compression when checked
Been lurking here for a while gathering info for my project. Love the site.
I recently picked up an 2001 ls1 and have been getting it ready to drop in. When I purchased the motor last week I was told it came out of a running car that was wrecked in the rear. I did a vin check and can see that it was salvaged almost one year ago next month. So it sat for a while drained of oil.
I did a compression check this morning after adding new oil and filter, and pouring some inside of the valve covers. With it still on the engine stand I also turned it over a few times by hand. My first compression check showed:
1) 120. 2) 180
3) 210. 4) 210
5) 210. 6) 60
7) 210. 8) 60
So I added a little oil to the cylinders and turned it over a few times and then let it sit for about 4 hours. When I rechecked it I got:
1) 150 2) 175
3) 195 4) 180
5) 190 6) 180
7) 180 8) 170
I checked the compression per the service manual, 4 cranks per cylinder. I recheked it 2 hours later with the same results as above.
My motor is still covered by the yards warranty and I wont be getting it running for a few more months, but I am at the stage where I am getting parts and having the ECU and wiring harness done. So Im not sure if the low compression was a result of sitting and being dry or I should take this one back and get another one?
I am very new to these motors so please excuse my lack of knowledge. I appreciate any insight you can provide.
Old 08-05-2012, 04:48 PM
Littered's Avatar
Does anyone have experience with a motor that sat dry for a while?
Old 08-05-2012, 05:08 PM
chevymec's Avatar
Sounds like the rings were sticking.
Old 08-05-2012, 06:08 PM
Littered's Avatar
Thank you for the input
I have checked a few more times since then and I'm getting a constant compression variation of 12% across all cylinders. Also I am only getting a difference of 6% at most between a dry wet compression check. Keep in mind this is on a cold motor.
Old 08-06-2012, 02:09 AM
bww3588's Avatar
If the motor is not in the car, how were you cranking the engine? By hand? Or did you have a starter hooked up?
Old 08-06-2012, 02:11 AM
bww3588's Avatar
The engine should also be a operating temp for a more accurate compression test since the pistons are cam ground meaning the clearances aren't where they should be cold.
Old 08-06-2012, 05:49 AM
redtail2426's Avatar
you wont get very accurate results turning it over by hand,and with it not being warmed up.I would drop it in and fire it up
Old 08-06-2012, 04:17 PM
Littered's Avatar
I had it on a stand with a starter and battery hooked up. I ended up trading for a 20,000 fewer miles motor. I dont think the pressure should be 60psi even when cold. Especially when all other cylinders were hitting 180s.
Im not anywhere near a point to have it dropped in and didnt want to worry about it. I appreciate the help!
Quick Reply: LS1 sat for a year wierd compression when checked
