Post your Heads/Cam setup + hp/tq #'s
#121
Ls2 sbe
Hand ported 799s shaved .030
236/242 615/612 cam on 114 lsa
Ported Fast 102 ,godspeed 102 TB
under drive balancer
Electric water pump
1 7/8 texas speed Lts
custom 3" y pipe to 3 to 4 flowmaster merge with bullet muffler dumped at the rear.
Manual steering rack
Yank pt4000 ,performerbuilt 4l60, 8.8 with 3.08 gears
495 rwhp, 437 trq on a dynojet
3520 lb race weight, 6.76 @102 with a 1.51 60ft
Like Hio and a lot of others on here have figured out the little things add up.
Electric water pump
#126
2000 TA running TR224/224 114 cam and TSP 5.3 heads milled to 59cc.
Car also has a LS6 manifold, slightly ported TB, Pacesetter LTs & ORY running through a Hooker catback. Made 414 RWHP & 395 RWTQ.
#132
Hand ported Dart 225s, custom ground comp core 243/251 112 lsa. 11.4:1
534.5RWHP 461ftlbs torque. 383c.i. NA pump gas.
https://www.youtube.com/watch?v=bSRpl1wrivU
#133
Forged bottom end 347 cubic inches
Trickflow 215's milled to 59cc 11.5 static compression
Fast ported 102 intake manifold
NW 102 TB
Vindicator cam (240/244 .605 .596 112LSA)
Texas Speed 1 7/8 headers
Texas Speed true duals with bullets
Fast toys ram air
Fast toys 98mm lid
Underdrive pulley
No MAF speed density tuned
466rwhp/416rwt through a M6 with 10-bolt and 3.42's
Cams are spec'd as part of the engine combo itself. I more restricted intake might have more lift or duration same goes for exhaust to try and band aid there shortfalls, a nitrous cam will have more of a split and exhaust duration to help get rid of the exhaust gasses. There is alot more that goes into it though and I'm not the one to try and give advise on the intricacies of valve timing. There are some great post on here and yellowbullet if your willing to search and do some researching.
P.S. Check out the dynometer section to see all the different results people are getting out of their combos.
NW 102 TB
Fast toys ram air
Fast toys 98mm lid
Underdrive pulley
SDPC 346 short block
MTI-Stage II LS6 heads
FAST 90 ported w/ Nick Williams TB
Kook LT's
228R cam
SLP lid
#135
SBE LS1 with 200K miles - damn thing wont quit
TSP Torquer V2 - installed at 176K
TSP 5.3 Heads (2.5) - installed at exactly 200K
LS7 Lifters
BBK LT's
LS6 intake
Ported TB
SLP Lid
TSP catback with cutout
405whp/386tq
LS7 Lifters
BBK LT's
LS6 intake
Ported TB
SLP Lid
405whp/386tq
#136
46k orginal mile sbe ls1
-Patriot stage 2 cnc ported 5.3 heads dual .650 springs
-TSP 231/237 598/595 112lsa
-Fast 92mm intake ported by Mamo
-Nick Williams 92mm TB
-ASP underdrive balancer
-LS6 oil pump
-LS7 lifters
-JWIS double roller timing chain
-Siemens deka 60lb injectors w/ Racetronix 255
-TR-6 plugs
-TSP 1 7/8th longtubes w/ 3" open ypipe
-Hawks lid with oem paper filter , no ram air setup
4l60e -Yank ss4000
8.8 -3.73 gears
Tuned on a 90° + day on 93 and speed density
432HP 381TQ
-LS6 oil pump
-LS7 lifters
-TR-6 plugs
4l60e -Yank ss4000
8.8 -3.73 gears
432HP 381TQ
