28 tooth vs 56 tooth crankshafts
The following 2 users liked this post by Darth_V8r:
00pooterSS (12-23-2019), G Atsma (12-23-2019)
The following users liked this post:
To actually tell what crank is in the engine...........look at the reluctor wheel..
If the engine has the correct crank sensor in it, then yes go off color. But what if some idiot through the wrong crank sensor in it?
The 58x wheel is one piece and solid. The 24x wheel looks like several pieces of metal that are stacked on top of each other like a samwich
G Atsma (12-27-2019)
A factory 58x reluctor wheel will be in a Gen IV engine, so you should also see cam sensor located on the front cover, and knock sensors on the side of the engine block (close to engine mounts).
But presence of cam sensor in front cover doesn't guarantee anything because most aftermarket cams are 3-bolt style, so if the engine had a cam swap then it might also have front cover with cam sensor.
