which cam ?
Old 11-02-2012, 01:43 AM
blak_ls1's Avatar
Default which cam ?
i know there might be a bunch of threads with this similar question but i recently bought another f body .. 98 ws6 trans am with 3.73s, ls6 intake,lid, LT headers,ORY , and a bullet, 3600 stall .. i was thinking of adding a cam... which cam do u guys recommend? thanks
Old 11-02-2012, 01:49 AM
arock24's Avatar
What are your overall plans?
What is your budget?
I would do some research and look at what both your current and future goals are going to be. There's quite a few of cars with similar setups to your's (hence one being my car). I love my torquer v3, but I would consider it a little more on the 'aggressive' side. Calling a vendor with your plans will get you pointed in the right direction as well.
Old 11-02-2012, 04:34 AM
mjs1012's Avatar
228r. You could even go a little bigger since you have gears in the car.
Old 11-02-2012, 09:55 AM
Sales1@Texas-speed's Avatar
Like mentioned above there is a ton of choices out there. Let us know what your looking to get out of the swap and what the primary use of the car is.
Old 11-02-2012, 10:02 AM
alexus6798's Avatar
I'm in the same boat. I've had two cams spec'd and I am still undecided My problem is I want MS4 or TRex sound but want 228R or similar performance..
Old 11-02-2012, 10:46 AM
The Scammer Hammer
dr_whigham's Avatar
Anything from Ed Curtis.
Fill out the sheet with your current mods and what YOUR goals are. He'll reach them, and then surpass them.
Old 11-10-2012, 11:44 AM
JPH
JPH's Avatar
Use a Crane #1449601 for your setup.
Old 11-10-2012, 12:00 PM
Mattyfresh89's Avatar
if its a daily driver 224 or 228
I love my 224 symmetrical and daily drive it everyday
Old 11-10-2012, 12:37 PM
MikeWS6's Avatar
I have the 228R and it sounds crazy at idle. No low end loss here.
Quick Reply: which cam ?
