Hydraulic lifter for race engine
Hi guys,
I have a 347ci LS1 built for racing, it has done 5 events,
Currently running a hydraulic comp cam (242/250 .619 lift) and am only using LS7 lifters, what lifters would be recommended for a full time race engine?
I see Comp have short travel race lifters that will require adjustable rockers,
Would I be better off going a solid roller?
Thanks,
David
Thanks,
David
Johnson and comp both have short travels. Neither of those require adjustable rockers if you measure your engine carefully on each valve...it is just a lot more work to do it and people are impatient. Plenty of people on here are running either of the above with non-adjustable rockers and custom pushrods.
