Weird lifter/valvetrain noise
Old 11-29-2012, 08:17 PM
SpdJunkie's Avatar
Default Weird lifter/valvetrain noise
Hey guys,
I just got back into the LS1 game with a 2001 SS that i bought from a member here on the board. I've been loving every second of it but for the last week or so its been developing a ticking noise coming primarily from the right/passenger side of the engine (valvetrain noise or possible bad lifter?). Maybe I'm just being paranoid but I figure i'd ask before i break something or do permanent damage. Here's a list of what is under the hood and a link to the video(hope it works) of the sound if it'll help...
http://www.youtube.com/watch?v=et_VA...ature=youtu.be
-4cc Mahle Forged Piston/Ring kit - Stock bore
ARP Head studs
ARP Rod bolts
Patrick G Spec'd Cam - 238/244 .615/.612” 113LSA +2 advance - Comp XFI/XFI lobes
TFS 215 Heads - milled to 57cc w/upgraded springs & custom length 3/8" pushrods
.040" cometics - 11.8-1 static comp (with stock pistons, now have -4cc)
Custom tune
SLP ported Oil Pump
Double Roller Chain/Adj Sprocket
LS7 Lifters
ASP Pulley
42 lb Injectors
Pacesetter LT's
Custom (hacked) TSP ORY with magnaflow cats bolted in
3" Hooker Exhaust into CME
Removed AIR
Removed EGR
MSD Plugwires
NGK TR6 plugs
Again, i hope i'm just being paranoid but who knows...
Thanks for the input!
Old 11-29-2012, 08:24 PM
chevybayboy's Avatar
Originally Posted by SpdJunkie
Hey guys,
ARP Head studsii
ARP Rod bolts
Custom tune
SLP ported Oil Pump
LS7 Lifters
ASP Pulley
42 lb Injectors
Pacesetter LT's
Removed AIR
Removed EGR
MSD Plugwires
NGK TR6 plugs
this is how mine sounded when I spun a lifter and cracked a tray
Old 11-29-2012, 09:38 PM
DietCoke's Avatar
sounds like a loose rocker arm. pull the valve cover and check
Old 11-29-2012, 10:05 PM
Crimson Vette's Avatar
Mine sounded the same as well. Started making the sound while I was driving though, in a construction zone with no where to pull over. By the time I got it pulled aside it had shut itself down.
After tearing it down found that the lifter had spun 90 degrees in its bore. Lifter tray didn't crack, but was weak enough to let it spin. Destroyed the cam and bent a couple valves.
I'd suggest pinpointing the location with a stethoscope and go from there. Good luck
Old 11-29-2012, 10:54 PM
LS1Tech Premium Sponsor
Sales3@Texas-Speed's Avatar
I wouldnt drive it, just need to tear into it and figure out what it is. Its easy enough to take the valve covers off and see if it something simple, or find out at that point if you have to tear further into it.
__________________
NOW OFFERING TSP BY YANK CONVERTERS
COMP - FAST - PACESETTER - WISECO PISTONS - LUNATI - CALLIES - NEW TSP BRAND CRANK & RODS - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - ARH HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - PRECISION INDUSTRIES - YANK - CIRCLE D - AND MORE!
NEW NUMBER (512)863-0900
Old 11-29-2012, 11:08 PM
Wow that sucks I just got up and running a few days ago from 8 months...
Old 11-29-2012, 11:51 PM
Crimson Vette what lifter tray were you using?
__________________
Old 11-30-2012, 12:12 AM
They were the stock lifter trays. Motor has 50k miles on it.
Old 11-30-2012, 12:27 AM
SpdJunkie's Avatar
Thanks for the replies. i think ill tear in to the valve covers this weekend and see if there's anything obvious. Tearing into an LS is one of the few things that i haven't ever had to do to an f-body in the past. Guess i wasn't running a big enough shot on my previous rides.....
Old 11-30-2012, 07:15 AM
Roarin_8's Avatar
Wow that's pretty loud, I thought the ticking noise I had was bad.
You have to listen pretty close to hear it. Click on image.
Old 11-30-2012, 09:47 AM
OffspringZ28's Avatar
Similar sound as mine, yours is a bit louder. I'm tearing into mine soon and replacing the oem lifters with Morels/changing cam/FAST 92. Might as well if I'm going in there already. My car also seems to drive fine, with great oil pressure. Keep us updated with your findings.
Old 11-30-2012, 09:52 AM
Yea I can barley hear it
Old 11-30-2012, 10:19 AM
CHADsterss's Avatar
Sounds like a bent pushrod to me.
Old 11-30-2012, 10:28 AM
Roarin_8's Avatar
Bent pushrod with an auto?
Old 11-30-2012, 10:32 AM
alexus6798's Avatar
You all are scaring the s%^t out of me. Everyday someone complains about lifters ticking and tearing up their motors. I bought LS2 trays to use with my lifters but I've been thinking bout breaking down and getting the morels..
Old 11-30-2012, 01:44 PM
SpdJunkie's Avatar
I have never had to open an LS1 before but i do consider myself pretty technically adept, so other than head gaskets, intake gaskets, exhaust gaskets, lifters and trays, what else will need to be replaced? Also, with head studs can i still get the heads off the car without removing the engine? Im sure there will be more questions to come....Thanks again
Old 11-30-2012, 02:04 PM
Yes you can my engine block is studded get new coolant cross over o rings if you plan to do cam now would be perfect and easier to do
Old 11-30-2012, 02:07 PM
I bent my pr wen I had an auto hit the limiter to hard and fast with no tune after a few upgrades
Old 11-30-2012, 02:25 PM
SpdJunkie's Avatar
Ill only change the cam if i absolutely have to. Between the way it sounds and the way it performs i really like it a lot
Old 11-30-2012, 06:47 PM
Roarin_8's Avatar
Before my car was tuned, I babied the hell out of it. It has hit the limiter when the slip code came on and put the car in limp mode but the car was tuned before that happened.
Quick Reply: Weird lifter/valvetrain noise
