Cam change or stock
Old 12-09-2012, 09:32 PM
Renegade6's Avatar
Default Cam change or stock
I have a 2004 Silverado 6.0 liter that is completely stock and I've figured out I have a bad lifter.
Thinking that since I have to change the lifters, should I do a cam swap? It's a stock truck and I'm only looking for mild performance upgrades.
What cam would you all recommend or, should I just stay stock?
Old 12-09-2012, 09:38 PM
Blk98Vert's Avatar
Something small like an LS6 cam would provide a mild upgrade at a cheap price
Old 12-09-2012, 09:47 PM
VandykeT/A's Avatar
Well, in order for you to really benefit from the cam your going to need headers and exhaust. Do you have a LQ9 or 4? You could home port the heads and mill them (check ptv) while you have them off but unless you plan on doing headers, cai, cam, springs, pushrods, possibly a torque converter, and a tune I wouldn't mess with it. I'd mill the heads a little to true them up or a little more than that if you have a LQ4 and just do some bolt ons if you want some performance. A cam swap will turn into alot of money because of all the supporting mods. If you want some more power I would just fix whats broken and do a few bolt ons and a tune. Good luck.
Old 12-09-2012, 09:58 PM
wildcamaro's Avatar
Yea and ls6 cam package, headers, and a tune would do ya good if looking for mild performance...
Old 12-10-2012, 12:08 AM
Gunslinger09's Avatar
Headers are nice but an LS6 cam will work well with the stock manifolds too. Since it will cost the about the same as a stocker you might as well go with one. I would have a good valve job done and install the LS6 springs on the heads and call it a day.
Old 12-10-2012, 12:15 AM
99Bluz28's Avatar
I'd go a little bigger then the ls6 cam, to make the effort worth your time and money.
http://www.ws6project.com/user_stor/...-lift-212-218/
-15* overlap
http://www.ws6project.com/user_stor/...oducts_id=4626
-11* overlap
http://www.engpwrsys.com/index.php?a...od&productId=4
-13* overlap
Old 12-10-2012, 12:21 AM
Aleken's Avatar
^^^Yea and ls6 cam package, headers, and a tune would do ya good if looking for mild performance...
Old 12-10-2012, 12:30 AM
wildcamaro's Avatar
^^^has anyone else ever had their post copy and pasted like this? It's the third time this has happen to me on this site...makes me wonder
Old 12-10-2012, 01:19 AM
2000PewterT/A's Avatar
No and that is not right, contact a moderator and they can probably take care of that.
Old 12-10-2012, 01:43 AM
chevybayboy's Avatar
Yea that's not cool what's the point ?? If he wanted to add his .02 should of word it different or something not word for word
Old 12-10-2012, 01:24 PM
wildcamaro's Avatar
Not that I care if someone copies a post, I'm thinking its some kind bot or something...ill pm a moderator
Old 12-10-2012, 08:17 PM
Renegade6's Avatar
I found a new LS2 cam for $90. Are these any different from what I have in it now?
Quick Reply: Cam change or stock
