My LS1 Committed Suicide Last Night! How?
Old 12-22-2012, 12:52 AM
Sinister_Z28's Avatar
Default My LS1 Committed Suicide Last Night! How?
Ok so i have a bone stock 98 Z28 M6 and when i was driving home last night on the freeway i heard a loud knock and i lost oil preasure. Next i saw smoke and heard metal fly off under the car as it died. After i got it home today i looked under it and i have two 1" holes in the block and i found a piston ring stuck under the car. How in the hell does this happen? I think it threw a rod but i dont understand how. All the fluids were good and it was driving fine shortly before. Ill post pictures tommorrow. Im looking for input so i can prevent this from happening in the future. Oh and the car has a 173,000 miles on it and im the third owner. Guess its time to build a 383.
Old 12-22-2012, 01:00 AM
SlowBurn's Avatar
Since your block is hosed anyways, why not build a 402 or 408?
Old 12-22-2012, 01:09 AM
1988montecarloss's Avatar
x2 or put an lq4 in it!
Old 12-22-2012, 01:15 AM
Ok im pretty new to the whole stroking thing and im trying to do this on a tight budget.
Old 12-22-2012, 02:37 AM
35th SS's Avatar
remember those rod bolts I mentioned to you on the pm.some upgrade to the katech ones some to the arp.
Old 12-22-2012, 05:16 AM
RezinTexas's Avatar
Then in your case I would find a stock LQ4 to swap in. You should be able to find one for around $1k with decent miles.
Stroking an engine and "tight budget" are on opposite ends of the universe.
Good luck and keep us updated with whatever you choose.
Old 12-22-2012, 06:00 AM
lemons12's Avatar
Check out Thompson Motorsports.. He has some amazing budget friendly choices.
Old 12-22-2012, 07:06 AM
ejbta2's Avatar
Check out Thompson Motorsports, Kyle will help you out. He has great customer service and quality. He hooked me up.
Old 12-22-2012, 07:07 AM
Blackpanther99's Avatar
I would just go with a bigger cubic inch motor 383ci make great HP but why not just go with a 408? Benefit more from it
Old 12-22-2012, 07:14 AM
Noobinit's Avatar
408 ftw!
Old 12-22-2012, 09:04 AM
Old Geezer's Avatar
May it have been an "assisted suicide"??? 3 owners, beating the crap out of the car, for nearly 200K miles????
Old 12-22-2012, 09:22 AM
senicalj4579's Avatar
My thoughts exactly.
OP might as well make it count if you can afford it.
Old 12-22-2012, 09:31 AM
blknSS's Avatar
Sucks now but your lucky...a 170k mile performance motor... I think that thing did its job and then some.
Old 12-22-2012, 09:51 AM
poltergeist 02's Avatar
same thing happened to a friend of mine. he has a Buick GS 455 that had a fresh motor. we just got on the highway, he ran it up to about 4K it knocked for a split second and boom. he thew a rod just like you. till this day we aren't sure why it happened, maybe a bad build/clearances, i don't know. just be greatful that yours had the milage that it did before it let loose. gl with your new build.
Old 12-22-2012, 10:59 AM
gMAG's Avatar
All things wear out, including your body.
I would stick to the light-weight block.
Old 12-22-2012, 11:10 AM
SSickLS1SS's Avatar
it could be as simple as not having the right amount of oil in it
Old 12-22-2012, 12:42 PM
As far as assisted suicide its probably true. Im the third owner and i maintain it very well but hey god only knows what its been put through. Ok so since i need a new motor and i want to stroke it because i am a fan of more cubes can someone explain to me what is a good size to go to without destroying the bank completely. This will be a street strip car.
Old 12-22-2012, 01:11 PM
Dirty Dog's Avatar
That wasn't suicide. That was old age. In human terms, your engine lived to be about 95 and then died from natural causes.
Old 12-22-2012, 03:09 PM
lemons12's Avatar
Tms has a 370 that is incredibly cheap..
Old 12-22-2012, 07:16 PM
meine96ws6's Avatar
170k isnt "a ton".... i mean if it was beat on then yes...
We just wrapped up a Procharger, ECS blower cam, ls6 intake manifold, lingenfelter p oil pump, new timing gears and chain, and other supporting mods such as seals and gaskets on my friends 190k mile, 99, c5...
Of course we did a new fuel pump and injectors...but its making 563 rear wheel on 9 psi.
We have a healthy tune on it, and have since added meth injection to help stay conservative.
Alsi, you don't need a stroker to make power.
Quick Reply: My LS1 Committed Suicide Last Night! How?
