Cam swap 5.3
Old 01-31-2013, 12:15 PM
Rangerlee11's Avatar
Default Cam swap 5.3
Is the 03 04 z06 cam a good cam for my 05 silverado 5.3 ho?
Old 02-03-2013, 10:49 PM
brooknasty's Avatar
yes, supposedly worth 40-50 hp. no mods required on non-AFM/DOD(active fuel mgmt/displacement on demand) engines
Old 02-03-2013, 10:50 PM
brooknasty's Avatar
of course a custom dyno tune is always a good thing!!
Old 02-04-2013, 06:39 PM
99Bluz28's Avatar
Sorry, but you're not going to gain 40-50 hp with that cam and the power you do gain will be in the upper rpm range. I'd go with at least a 212/218 cam with a lsa ranging from a 111-116lsa, all depending on what type of use the truck will see.
Old 02-04-2013, 06:46 PM
Blackpanther99's Avatar
A 224 cam is probably the most used cam in a 5.3 daily driver truck. Its a good size cam with some good amounts of HP gaind.
Old 02-04-2013, 06:47 PM
Coming from a person that lives in a very truck performance influenced town lol
Old 02-04-2013, 06:59 PM
garygnu's Avatar
look at comp 54-408-11,or 54-455-11.
Old 02-04-2013, 09:43 PM
DMM
DMM's Avatar
^ This. Since you have truck, you need torque. I have this same cam in my '03 Silverado (COMP 265 low lift) and it's stronger than a 6.0 down low and pulls like my LS6 up top. IIRC, the Cam Motion 212/218 on 113+4 gives the best of everything. The 212/218 is perfect cam for a N/A 5.3.
Quick Reply: Cam swap 5.3
