Sounds like a bird in my engine bay
Old 02-10-2013, 11:50 PM
Sommer86's Avatar
Default Sounds like a bird in my engine bay
Hi guys,
About 2 months ago I started noticing a funny sound that sounds like a bird on the drivers side on my engine. It goes "chirp" with the engine RPM, but no noticeable power loss.
Thinks it's a rocker, or a pushrod or possible an exhaust leak??
Anyone heard of this before? I can get sound clip if needed.
Thanks.
Old 02-11-2013, 06:00 AM
DarkJuggalo's Avatar
sound clip is always your best bet. have you checked all the belts/pullys?
Old 02-11-2013, 06:27 AM
oChristiano's Avatar
Honestly Sommers it sounds like a lifter tick when I heard it. Pull valve cover and check all rockers/push rods. Cycle engine and check all lfters when valve is closed. When I lost the lifter in my SS one of my push rods were silver on the end. There was no real noticeable power loss until the car fell flat on its face racing Lee and the lifter exploded. I wrote it off as an exhaust leak(which I did have..)
Old 02-11-2013, 06:39 AM
Grimes's Avatar
Look at your ac belt tensioner, and you main belt tensioner. If they are bouncing around, they need to be replaced.
Old 02-11-2013, 06:52 AM
lemons12's Avatar
Probably not it... But spun bearings resemble that noise.
Old 02-11-2013, 07:13 AM
SteelCityYaga's Avatar
What's the frequency of this chirp? You said it goes along with the rpm is it like a constant chip, so it would really be a squeal? Or is it once every few seconds?
What are the mods and particular mileage on these mods?
Old 02-11-2013, 07:19 AM
I actually heard this for the first time recently on my friends 6.0 I thought it might of been cam bearings. I'm used to rods knocking when bearings spin.
Sommers easy way to check if its an exhaust leak, harder for an auto but get on freeway or something next to a wall. And give it gas but not enough that it down shifts. If tick stays with rpms its engine. If it gets louder/faster its exhaust.
Old 02-11-2013, 09:13 AM
Super Hulk Smash
JakeFusion's Avatar
Is it at idle or only under load? Does it increase with RPM?
Old 02-11-2013, 04:21 PM
3rdCoastPowerSports's Avatar
u sure your crank pulley is not wobbling causing the belt to chirp
Old 05-08-2013, 06:57 PM
Sommer86's Avatar
Here 's a video....FINALLY!
Old 05-08-2013, 06:59 PM
FiredUpZ28's Avatar
X2
SUPER common in Vettes it seems like but definitely where I would check. Has anyone been in the motor for anything?
Old 05-08-2013, 07:05 PM
Super Hulk Smash
JakeFusion's Avatar
Doesn't sound like a belt. Sounds like something is rattling. How are your motor mounts? Does it do it when you brake hard?
Old 05-08-2013, 07:08 PM
Wimimc's Avatar
Thats an exhaust leak. Had the same exact sound when my header gasket went to crap. When I went to replace it I could see black soot marks on/around the header and head where it was leaking.
Old 05-08-2013, 07:47 PM
Carter01's Avatar
Exhaust leak.
Old 05-08-2013, 07:54 PM
poltergeist 02's Avatar
LS1Tech 10 Year
If it's not belt/pulley noises then I would pull the pushrods to see if one is pluged up. It also sounds like lack of oil to a rocker. It's hard to tell from a vid.
Old 05-08-2013, 07:57 PM
99 2500's Avatar
LS1Tech 20 Year Member
I would remove belts to see if it's a tensioner or idler pulley bearing first.
Old 05-08-2013, 08:03 PM
Super Hulk Smash
JakeFusion's Avatar
That's not a belt noise. My car has a belt noise and it's nothing like that.
It sounds like something is loose. Exhaust leak at the header would do that.
Old 05-08-2013, 08:56 PM
LS1Tech 10 Year
Maybe not a belt, but it could be a bad bearing in a pulley though.
Old 05-08-2013, 09:13 PM
Super Hulk Smash
JakeFusion's Avatar
It all sounds the same. Bearings cause a sustainer squeal. Easiest way to rule out belt is to run it without one. Or just spray water on the grooved side of the belt to lubricate/alleviate tension on the serpentine setup. If it doesn't come back while the belt is lubricated (couple squirts from water bottle should last 10 secs until it evaporates) then you know it's a belt issue.
Old 05-08-2013, 10:11 PM
stroked383HSR's Avatar
spun bearing in my 383 SBC in my IROC when i had it.
I sure hope its not but sure sounds the same.
I spent a crap load of money on that motor and never really got to play with it. Got me in all kinds of trouble is what it did...LOL
Quick Reply: Sounds like a bird in my engine bay
