Trans AM 2002
Old 03-23-2013, 03:32 PM
demonoidcreeper's Avatar
Default Trans AM 2002
Hey guys just got rid of my 2001 v6 camaro that ive had since 2008 and baught a 2002 Trans Am with only 55k miles. Its all stock except they took off the muffler and added a flowmaster it sounds good to me. Just want to know some pointers of what i should do to my TA, trying to get 400 HP out of it and im happy.
Any and all suggestions are much appreciated
2012 Toyota Camry SE
2002 Pontiac Firebird Trans AM 5.7L LS1
Old 03-23-2013, 03:40 PM
Any Takers???????
Old 03-23-2013, 03:44 PM
NoHope's Avatar
Get rid of that Flowmaster muffler!
Old 03-23-2013, 03:46 PM
Burken01's Avatar
Well you will want to start with a Head/cam kit to get you close to your 400hp goal...
I like texas speeds packages because they have alot of what you need minus a few parts..
http://www.texas-speed.com/p-1160-pr...m-package.aspx
this is a good start, this kit will get you to 400hp... they have other stages of port work and the price goes up from there..
Trickflow, AFR, etc.. those are aftermarket castings and usually out do ported GM castings (241,853,243)
and then you will want some headers to help it all breath better, then a tune...
Old 03-23-2013, 03:49 PM
Burken01's Avatar
I see your in texas, I was born in Austin... I miss texas, shoot you live in one of the hottest spots for LS performance!!!
hopefully your close to some of the good vendors on here, Texas speed, Jakes performance, Circle d....
Old 03-23-2013, 03:50 PM
Thanks man ill check out that site and see into it, if I get a head cam kit is it something they can remove and put the new one on or is it a long drawn out process of taking the engine out and tearing it down!
Old 03-23-2013, 03:51 PM
Live in wichita falls, two hours from dallas and yeah they got places their so not to bad!
Old 03-23-2013, 03:56 PM
Burken01's Avatar
you dont have to take the engine out to do a heads/cam but If you havent worked on your car before you will need to do alot of research beforehand...
heres the just of it
http://www.ls1howto.com/index.php?article=2
if it looks too involved or your not comfortable then you can always start with "bolt on's"
like Long tube headers, exhaust, you have a ls6 intake already which is good (can always upgrade to a FAST intake down the road) If your an automatic you can get a stall converter which I recomend to be your first mod if you do have the A4 (automatic 4spd)
Old 03-23-2013, 04:04 PM
crazy it has the ls6 intake, is that the plastic manigold thats up tope or the sensor after the ait flows in?
Old 03-23-2013, 04:12 PM
read through that information and its very helpful yeah i will definatly have to find someone to help with that!!!!!
Old 03-23-2013, 04:33 PM
hey nohope what is a good exhaust to use I want something loud and good performance?!?!?!?!?
Old 03-23-2013, 04:35 PM
Burken01's Avatar
Yea plastic manifold is the ls6 intake
Old 03-23-2013, 04:37 PM
no way really thats bad *** they should have just put the ls6 in the vehicle to begin with, The LS1 is badass but that would be cooler!
Old 03-23-2013, 04:53 PM
Burken01's Avatar
They probably would have if the f bodies didn't get discontinued in 02...
The gto got it in 05 so it looks like we missed it by 3 years. Oh well you can get a head/cam package and blow away the ls6 engine
Old 03-23-2013, 10:16 PM
garygnu's Avatar
a texas speed torquer v3 cam will make 400rwhp.get a good exhaust system ,and a ported TB.delete the cats.consider a mail order tune from Frost.get a ls2 timing chain and a comp cam trunnion bearing upgrade for the stock rocker arms.
Old 03-25-2013, 05:14 PM
im getting rid of the flowmaster just trying to figure which would be best! everyone says to get rid of it for some reason!!!
What muffler should I get put on their, I want something loud and really good performing????
Old 03-25-2013, 05:23 PM
Burken01's Avatar
slp loudmouth 1, its loud
Old 03-25-2013, 05:27 PM
MMWS6's Avatar
Loud and AWESOME!~
Old 03-25-2013, 05:28 PM
chawin's Avatar
Have about $3k+ to do it.
This was my intentions and was going to be happy with 380-400rwhp and a goal of $2500 and im now bumping close to $5k into this. Although I am doing EVERYTHING... trunions, clutch, slave, lifters, dual valve springs over beehives, but I did opt for CNC ported heads which was a little better than a grand in itself but now I should be looking closer to the 440rwhp range. You get this thing in your head that goes well youre already this far you might as well do it right and not leave anything on the table that leaves you wanting more or you will get it together and think I shouldve just done the lifters or went with ported heads etc. but pretty much what everyone is saying above is what you will need. You should already have the LS6 intake beings youre a 2002 so next would be cam, valve springs, push rods, long tubes, off road y pipe if you can get away with it in your state. Recommend lifters but that involves removal of heads, trunion upgrade, oil pump, timing chain, o ring for the pick up tube then of course tune and such. List keeps going.
Old 03-25-2013, 05:42 PM
Burken01's Avatar
Well if you have an addictive personality like me, then you won't be satisfied really easy... If your going to do mods to your car, make sure the supporting mods are involved there too..
But if I were you I would ditch the v6, too much of a hassle and too much $$ and too much time...
Quick Reply: Trans AM 2002
