Current setup vs "GOAL" setup
Hey guys, I have an LS1 swapped 350z. I've searched and read lots of setups. Im currently sitting at about 400rwhp. I want another 50-75rwhp. This is a track car. I beat the hell out of it, and wanna keep it as reliable as possible. This is my current setup:
Ls1 Stock bottom end
317 heads shimmed/milled down (forgot how much) with some porting
Dual Valve springs
233/239 Comp Cam
Trick flow pushrods
Ls3 lifters
Ported and shimmed oil pump
Ls2 timing chain
Rod bolts
Ls6 intake manifold
1 3/4 long tube headers
3" X pipe and exhaust
Underdrive Pulley
CUSTOM short ram intake with K&N filter
Stock T/B
Stock injectors
Deatschwerks 300lph Fuel pump
Now, what would it take to make another 50-75rwhp? Any other bolt-ons I can do to reach that goal? Maybe Fast intake, t/b? What would you guys suggest? If not possible, I guess I'd have to do another H/C package?
Here's a quick vid too:
And another:
Thanks in advance. Im kinda new to the LS world.
Dual Valve springs
233/239 Comp Cam
Trick flow pushrods
Ls3 lifters
Ls2 timing chain
Rod bolts
Ls6 intake manifold
Underdrive Pulley
Stock T/B
Stock injectors
And another:
Fully CNC ported and milled GM heads or aftermarket heads, and at least step up to a mildly ported FAST 92/92 intake/TB. I'd also upgrade to larger 42lb injectors.
What's the LSA on your current cam, how high do you normally spin it, and what rpm range do you feel you need more power?
LS1Tech Sponsor
I would leave the cam alone at least for the time being. Do a FAST intake/Throttle body and a set of really good heads. Some TFS 215's, AFR's, or WCCH/AI 243's ported. That should put you all over 450-475 rwhp with a good tune
__________________
See what's in our shop on Facebook! Customer Build Blogs!
www.pcmofnc.com
Performance Installs - Dyno Tuning - Custom Camshafts & Valvetrain - Remote HPtuners Tuning - Mail Order Tuning & Sales
704-307-4227
www.pcmofnc.com
704-307-4227
LS1Tech Sponsor
Also I would get that filter outside of the engine bay somehow. I've picked up 20 rwhp pretty consistently doing this on the Trailblazer SS's. Do all the intake plumbing in 4 inch and loose the MAF sensor SD tune.
__________________
www.pcmofnc.com
704-307-4227
www.pcmofnc.com
704-307-4227
Now if only Nissan would make the Z like this to begin with. You know, the 350Z having a 350ci engine and not a little 3.5L engine.....lol
Very nice ride, can't wait to see the numbers it produces with your upcoming setup.
Well GOAL was not made!
I should have listened to u guys and went with the Trick Flow heads. Long story short, I was talked into MTI custom CNC ported heads so I bought some CNC ported heads from MTI. They decked them as much as possible and brought it down to 63cc. I did get the ported fast 90 intake, and a fast 90 t/b. Final numbers after all said and done: 415rwhp/380 torque. Only gained another 15-20hp!
So next question, I keep hearing I should change my cam out. I obviously need to up my injectors as well, which haven't done so yet.
So what cam would u guys suggest?
Current cam: 233/239 600 lift 113/2 LSA.
