Pics Of My Advanced Induction Dart/RHS 223cc Heads/Build Thread
Old 12-25-2013, 10:24 AM
  #361
greenvortec97's Avatar
Originally Posted by AINT SKEERED
Nice car and combo. With some tweaks you will get it sorted out, mine took a while to get the right parts working together.
I had my car on Futral's dyno and Geoff's dyno. Both made the same power.
As I changed from Allan tuning my car to getting efi live my self and Geoff teaching me how to use it I tuned both my Nova and my Trans am at the track using an Lm1 wide band . by track tuning and tweaking , both cars went to Geoff's dyno and after several pulls on both cars never found any more power on the dyno then the first pull. I was impressed with my self and so was geoff but I still had geoff help me clean up the idle and some drivability issues.
Just shows that tuning for mph is the best bet and you can also do that by data logging on the street and looking for what makes the car excelerate faster on data logg. Not seat of the pants.
Dyno is just to impress on the INTERNET not to make the car faster.
Dyno won't load the car like the street will.
As seen earlier on here, I also set my stoich at 14.2 and like 12.5/1 wot because ofthe added ethanol in gas these days.if your using nonetheno gas only then 14.68 stoich and 12.8-13.2/1 is where good power is made.
Also I'm not big on high timing, have not seen much performance gain at the track going from a safe 27.5 deg uo to 29 of timing. Good combustion chambers dont need as much and with the compression your running it should not need it.
Just my 2 cents, Merry Christmas.
Same here on timing, my car liked 25-26* at the track
Old 12-25-2013, 10:48 AM
  #362
Zmg00camaross's Avatar
Think mine is at 27.5 timing. All street tuned. Runs and drives just fine and puts the mph down.
Old 12-25-2013, 06:56 PM
  #363
The Scammer Hammer
dr_whigham's Avatar
My car liked 29* the best
Old 12-25-2013, 10:09 PM
  #364
Rise of the Phoenix's Avatar
Thanks guys. The car is OLSD tune. Once it warms up some, I'm going to take the car out and get some wide open throttle runs in and see where the air/fuel reads at. Some very good information in here guys; much appreciated.
Old 12-26-2013, 05:24 AM
  #365
The Scammer Hammer
dr_whigham's Avatar
Sheer curiosity- why are you in open loop instead of closed loop?
Old 02-19-2014, 01:55 PM
  #366
mchicia1's Avatar
Ever get any MPH results?
Old 02-19-2014, 06:33 PM
  #367
No, but will here soon.
Old 02-19-2014, 07:09 PM
  #368
You let me know! We can get it working.
Old 05-23-2015, 09:21 AM
  #369
hodge9386's Avatar
so did you ever get this thing lined out? im thinking about getting some heads for my c5 and am curious about the rhs heads.
Old 04-11-2016, 02:53 PM
  #370
Wanted to update this thread a bit. My 1 7/8" headers will be here Wednesday, and they should be on the car by this coming weekend. A buddy of mine, and the guy who built my car, now has a dyno in his shop. I'm going to get some dyno numbers on his dyno with the 1 3/4" headers and then some after dnyo numbers with the 1 7/8" headers and some touch-up tuning. I think the bigger headers are going to net me around 15 or more RWHP. The headers I have now are 1 3/4", but also have 2.5" collectors, so going to a 1 7/8" setup with 3" collectors is going to do a lot for the combo I believe.
Old 04-11-2016, 02:57 PM
  #371
Nice! Would like to see the comparison!
Old 04-11-2016, 03:10 PM
  #372
Another similar setup gained 25 or so RWHP going from 1 3/4" to 1 7/8" headers, so if I gained that much, I'd be really happy. I think around 15 rwhp is more realistic. Next on the agenda will be the FAST 102mm/102mm combo.
Old 04-11-2016, 04:47 PM
  #373
Jtm2085's Avatar
Subscribed. I am on the process of swapping from tsp 1 3/4 to 1 7/8 myself
Old 04-11-2016, 08:16 PM
  #374
AINT SKEERED's Avatar
I will be watching for the results
Old 04-11-2016, 08:29 PM
  #375
BREWS02WS6's Avatar
This will be nice info! You should make a thread in the dyno section and link to it in here. Make it easier for people to find that kind of comparison. What are your hp/torque numbers now?
Old 04-12-2016, 08:07 AM
  #376
418 rwhp 380 rwtq. I think the torque number was so low due to the 2.5" collectors on the headers. This will not be done on the same dyno as those numbers came from, but we are going to do some pulls with the setup as is, and then some pulls after the bigger headers are installed, so it will be a true back to back comparison.
Old 04-12-2016, 08:11 AM
  #377
Jtm2085's Avatar
Awesome, what does the rest of your exhaust look like?
Old 04-12-2016, 08:17 AM
  #378
3" Texas Speed true duals dumped. One other change, though small, will be that I'll be putting on two SLP Loudmouth 1 resonators on in place of the Texas Speed bullets.
Old 04-12-2016, 08:44 AM
  #379
Jtm2085's Avatar
I got ya. I went from a y pipe set up to the tsp duals and felt a decent difference.
Old 04-12-2016, 10:25 AM
  #380
Yeah, I'm going to do that. Any guesses on how much you think the bigger headers will pick up? The reason I think it's going to be pretty significant is because of how well the heads flow.
Quick Reply: Pics Of My Advanced Induction Dart/RHS 223cc Heads/Build Thread
